Mag ML25LT reflector and lens
Anyone have a source for an aluminum reflector and glass lens for a Maglite ML25LT?
Glass lens you can get from flashlightlens.com. Unfortunately I’ve tried about seven different aluminum reflectors, and none of them work. They’ll either be just the wrong size or do not have the right focal point at least not for incandescent. I know you have the LED model. Unfortunately, the only reflector that I got that fit, Kaidomain No longer has. That being said, why? The reflector is already perfect. The only reason why I wanted an aftermarket one was because of the heat generated by the incandescent Bulb
Why? I ask myself that many times when it comes to these projects. Thanks for the info.
