Hello BLF members,
Most flashlights with magnetic tailcaps are designed strictly as close-range flooders or mule work lights. While sticking a wide flood beam under a car hood is standard practice, we’ve seen growing interest in putting strong neodymium magnets on dedicated, high-candela compact throwers.
We wanted to start a technical discussion on the design trade-offs between linear magnetic throwers, wide flooders, and 90-degree work lights—and see how the community views these different configurations.
Linear Magnetic Lights: Extreme Candela vs. Raw Lumens
The Wurkkos TS22 is widely regarded on this forum as one of the best value 21700 magnetic flooders. It outputs a massive 4,500 lumens via Cree XHP70.2/70.3 and offers convenient reverse power-bank charging.
However, optical reach is where the philosophy diverges:
| Metric | SPERAS M4 V3 | Wurkkos TS22 |
| Emitter | Luminus SFT42R (Round-Die) | Cree XHP70.2 / XHP70.3 |
| Peak Output | 2,200 lm (2,800 lm w/ TB217 tube) | 4,500 lm |
| Peak Intensity & Throw | 122,500 cd / 700 m | 9,150 cd / 228 m |
| Host Length | 85.6 mm (Ultra-compact) | 122 mm |
| Bare Weight | 91 g | 95 g |
| Battery Platform | Modular: 18350 (standard) or 21700 (extended) | Fixed 21700 |
| Tailcap Magnet | Flat neodymium base | Flat magnetic tailcap |
| Charging | USB-C (45-min fast charge on 18350) | USB-C with Reverse Power Bank |
The Engineering Trade-Off:
The TS22 lights up an entire front yard with a smooth wall of light, but at 9,150 cd, atmospheric moisture and distance will quickly wash out the beam beyond 100–150 meters in practical use.
For the SPERAS M4 V3, we paired the circular-die Luminus SFT42R with a focused smooth reflector. At 122,500 cd, it produces over 13 times the beam intensity of the TS22 from an 85.6 mm chassis.
By retaining a flat neodymium tailcap on the M4 V3, you get a miniature 18350 thrower that can anchor horizontally to machinery or a truck bed and throw a distinct, concentrated beam down a long pipeline, fence line, or perimeter without needing a tripod.
The 90-Degree Alternative: Why Right-Angle Solves the “Stuck to a Wall” Problem
A known limitation of mounting any straight-body flashlight horizontally to a flat vertical surface (like an electrical cabinet) is that the beam projects parallel along the wall rather than into your workspace.
For dedicated close-quarters tasks, our SPERAS SH20 takes the right-angle route:
Optical Setup: 3 × LEDs under a precision multi-TIR lens delivering 3,000 lumens of wide, artifact-free flood (173 m reach).
Workplace Geometry: Sticking the tailcap to a vertical beam points the 90-degree emitter straight out into the work area.
Dual-Fuel Driver: Runs on an 18650 cell for 300 hours on ECO (5 lm), but also natively accepts 2 × CR123A primary lithiums for sub-zero emergency readiness where standard Li-ion cells sag.
Weight: 56 g bare aluminum chassis, compatible with headband mounting or dual-direction pocket clip carry.
We’d Love Your Feedback:
Magnets on Throwers: Do you find a strong tailcap magnet practical on a dedicated pocket thrower like the M4 V3, or do you prefer your throwers strictly clean/non-magnetic to avoid metal shavings and compass interference?
Dual-Fuel Preference: In 18650 right-angle work lights, how important is CR123A primary backup support to you versus pure 18650 optimization?
Looking forward to your real-world thoughts and critique!
— The SPERAS Team
