Maha C9000 overcharging?
Hi BLF I have recently bought a Maha C9000 NiMH charger to charge my eneloops. I have read a few times recently though that when this charger says a cell is “Done” it actually terminates slightly early, and needs to trickle charge for 2 more hours before the cells are completely charged.
Does anyone know what happens after the 2 hours is up? Does it shut off completely or does it continue to trickle charge forever? Can it damage the cells if left for for too long after charging has “completed”? I’d love to know for when I am trying to group cells with similar capacities (these cells get used mainly in a 6 cell light)
Any thoughts? Thanks.
You should try giving Eric Cheng at Maha Energy a call…he was very helpful to me when I bought 2 9000’s from Amazon and one of them was an extremely old-production model….he swapped it for me no charge:
(800) 376-9992 (cust svc.)
(626) 363-9017 (support)
oops…I see you’re in Australia…maybe use Skype, or try emailng him at:
tech@mahaenergy.com
if you like,since I’m in the USA, I’ll call him for you and report back…
also:
How does the MH-C9000 detect end-of-charge signals from the batteries?
The MH-C9000 uses a combination of Negative Delta V, Zero Delta V, Peak Voltage, time and temperature to determine the end-of-charge. In addition, proprietary algorithms are used.
It does turn off after the trickle charge phase. You can see this by watching the displayed voltage slowly drop after the two hour trickle charge.
You can test it this way:
Charge two equally aged cells at the same time.
After the two hour trickle phase has completed take one of the cells out of the charger. Leave the second cell in the charger.
Wait for how ever long you feel appropriate (a couple hours or more is probably sufficient), and then remove the second cell from the charger.
Compare the OC voltage of the two cells.
The first cell's voltage will have likely dropped about 30 to 50 millivolts from the ~1.47 termination voltage, assuming a healthy cell. The second cell's voltage should be pretty close to that of the first. If the charger had continued to charge it, the second cell's voltage would be noticeably higher than the first cell.
Edit: The 9000 uses -dv, a timer, temperature and voltage as termination indicators. Early versions used -dv as the primary termination indicator but later versions use 1.47v as the primary termination indicator. Because that does not result in a complete charge, a trickle charge phase @10mA was added at the same time. I don't recall whether that trickle charge was ever without a time limit, but my copy, purchased more than three years ago does have the two hour time limit.
Wow thank you guys for the info, I really appreciate it! I will not be concerned if any of my cells stay in the charger for a couple of hours longer any more!
Thanks again, Ben.
