I found this DIY project on YouTube, it looks like an interesting project:
It’s designed to be operated with just one hand, with easy control of brightness, and can be powered by either batteries or an AC adapter.
Can be built for around £25 if you get the CPU cooler for cheap.
Major parts list (most ship worldwide):
Lens and Reflector:
Voltage Booster (there are two layout varieties floating around. If yours has a different layout than the one I used in the video, then use your own judgement when it comes to wiring up the input/output wires, which should be clearly marked on whichever layout you receive.):
eBay: Electronics, Cars, Fashion, Collectibles & More | eBay
Amazon: Amazon.com
High-Capacity Battery (lasts for AGES):Electronics, Cars, Fashion, Collectibles & More | eBay
CPU Cooler (Titan Fenrir in my case, but you can use any tower style cooler you like. Used ones can be found for around $20):
Amazon: http://www.amazon.com/gp/search/ref=as_li_qf_sp_sr_tl?ie=UTF8&camp=1789&creative=9325&index=aps&keywords=Titan%20Fenrir&linkCode=ur2&tag=dp059-20&linkId=SII6I4CB5O7QLFDO
10k Potentiometer:
Amazon: Amazon.com
Heatsink Plaster (glue):
Amazon: Amazon.com
Heatpaste:
Amazon: Amazon.com
M2 Nuts:
Amazon: http://www.amazon.com/gp/product/B009EFMQKY/ref=as_li_tl?ie=UTF8&camp=211189&creative=373489&creativeASIN=B009EFMQKY&link_code=as3&tag=dp059-20&linkId=T35VH2OQOZ5XKGP4
M2 Screws:
Amazon: Amazon.com
Nylon Spacers:
Amazon: Amazon.com
Mini Step Down Regulator (for the fan):
Amazon (US Only): Amazon.com
60cm Aluminium Bars (UK only): Electronics, Cars, Fashion, Collectibles & More | eBay
M3 Nuts:
M3 Screws:
1/4” to 3/8” Tripod Thread Adapter:
Amazon: Amazon.com
XT60 Connectors:
http://www.eachbuyer.com/10-pairs-xt60-bullet-plugs-connectors-male-female-for-rc-battery-toys-p176684.html
The following are best sourced locally:
3/8 Nut
Power Switch
Thick Wire
Rubber Feet
Full parts list, with remaining components: https://docs.google.com/document/d/1K…
