Hello my friends!
if you already have read the review - just klick my aff-link if you want one :D
Manker Rambler (non aff for aff-haters)
Code: MR001 Price: $ 32.-
otherwise read the review and decide then if you want to buy ... ;)
This Story starts as many do…
with a box:
inside: a plasic bag and a piece of foam ?
silly me! there is a flashlight underneath ;)
and thats in the box:
the Manker Rambler flashlight, a USB A-micro cable, a spare O-ring and a spare rubber boot for the tailswitch
time for a .gif ….
the specifications:
Product name: |
MANKER Rambler CREE XM-L2 960LM LED Flashlight |
Brand: |
MANKER Rambler |
Emitter Brand: |
Cree |
Emitter BIN: |
XM-L2 U2 |
Total Emitters: |
1 |
Material: |
6061-T6 Aerospace-grade aluminum alloy body Military Specification Type III- hard anodized |
Modes: |
Low:30lumens;150h Mid:180lumens;8h High:450lumens;4h Turbo:960lumens;1.5h Strobe:960lumens |
Brightness: |
960lm |
Distance: |
185m |
Battery Configurations: |
1 x 18650(NOT included) |
Switch Type: |
Clicky |
Switch Location: |
tail switch |
Lens: |
Ultra-clear tempered glass lens resists scratches and impacts |
Waterproof: |
IPX 7 |
Impact resisitance: |
1m |
Color: |
Black,Brown,Dark gray |
Weight: |
100g net weight |
135mm(Length)x30mm(Head Dia.)x27mm(Body Dia.) |
you can buy it at banggood.com (afflink)
another one shows us what is special on this Light:
it has a USB charging port which is covered and sealed by a swivel nut
there is also a charging indicator (green is full / red is charging)
i charged one battery over night and it came out at 4,18V
the light turned green at about 4.05 Volts the evenong before….
i tried several batteries with different voltages to meassure the charging Amps:
Batterie Voltage |
2,39 |
2,92 |
3,06 |
3,98 |
4,07 |
4,11 |
4,17 |
Charging Amps |
0,85 |
0,8 |
0,6 |
0,165 |
0,1 |
0,06 |
0,02 |
at the tailcap there is a hole for a lanyard
opened the light
lubed O-ring and nicely square cut threads
the tailcap from inside:
quite long spring…
orange peel reflector
perfect centered Cree XM-L2
on the hot end i could only remove the lens - the head seems to be heavily glued and the reflector didn´t move a bit…
btw: plastic bezel
backside of the driver
some comparison to a similar flashlight:
the Rambler can tailstand…
someone had the same idea
the Rambler does not need a special battery - but it has to be swiched “on” to enable charging
the Rambler is on the right
no coating un the Rambler…
just for fun---
a LD10 (NeutralWhite) , the Rambler (CoolWhite) and a convoi S2+ Red (WarmWhite)
under UV light the emiters show their differences
beamshots!
distance was 20cm
1/30 sec / F22 / ISO400
gray! wall, distance was 2.5m
0,62 sec / F22 / ISO400
side by side with the Olight R20 seeker
some numbers:
Light |
high |
Mid2 |
Mid1 |
low |
Manker Rambler (INR S25R) |
3,1 A |
1,65 A |
1,03 A |
0,14 A |
Manker Rambler (pana pull) |
2,55 A |
1,47 A |
0,94 A |
0,13 A |
1000 Lm* |
555 Lm |
359 Lm |
51 Lm |
800 Lm |
480 Lm |
326 Lm |
49 Lm |
Olight R20 (INR S25R) |
760 Lm |
138 Lm |
*1000 Lumen dropped due to heat to 930 within 30 sec
conclusion:
CON:
the tailswitch is on the strong side
no AR coating
no Anti roll whatever
no holdter or lanyard included
SO - SO:
quite heavy - but mass helps with the heat….
anno is on the shiny side
the both middle Levels are visually veery close
PRO:
well crafted
no dings or scratches
good price
USB charging works with any LiIon battery
feel free to ask for what i did not cover!
