long story short - i dropped it - from about 3 feet high, normal arm height, on a regular asphalt street
the button cover popped out and got lost on the asphalt, it was wet and raining and it is the same color as the street
found it after 15 + minute search, though i knew where i had dropped the light
light was still working but hard to press button now, it is very recessed without the lost part
also not waterproof any more, naked circuit components are visible through the hole
after finding the cover, i thought well i can glue this back
E6000 glue did not stick, silicone glue did not stick, epoxy did not stick
then i noticed that the installation seemed to be from inside the light
i figured i can take it apart and put the button cover back
but the drop had also bent and ruined the threads to the outer steel ring holding glass, o ring and reflector on
had to cut 2 slots in the ring, with hack saw just to get it started, still very hard to get in and out
after all that, and removing an inner threaded ring, the innards still are glued in or something
i STILL can;t get to where the button cover would go back
put it all back together, try different glue
alumaweld, i think - meant for sealing trailers against rain or something, silicone stuff again but smells awful
now the light is sawed, dented, scratched, the ring won;t go back as far down as it was, not sure why
it has glue all over it
looks like $##$
it does still work_UPDATE - that glue didn;t stick either, i had to make another hole cover AND button pusher AND reglue the actual switch back together (the steel contact part had also come apart from the bottom where it makes the actual connection)
it is working again but looks worse and worse now as i go on
hack sawed slots in the front ring, jerry rigged button cover that might come off anyway, switch that may fall apart again rendering the whole light useless
but what a weak design
one drop makes button cover fall off, can;t glue back, needs to go inside but the inside is inaccessible, drop also damages threads, can;t even take reflector out easily, not sure it is waterproof any more [glued button cover], and not sure the current glue will hold…
so the astrolux s1 is the only survivor so far [but it’s the newest light i have]
of course it is bigger than the manker, which is bigger than the dqg tiny IV 18650, which the manker replaced after i had 2 of the tinys go bad
it starts to seem like none of this stuff is actually rugged, no matter what they claim
no i do not want to pay $90 for the latest nightcore or whatever, only to find they took similar design or manufacturing shortcuts this time
wle
