MascaratumB
(MascaratumB)
19
I had some time tonight and made a little bit of the flashlight mod! The first and most insignificat part
I replaced the rubber cap!
The original was a black one, and I put an orange one. I had to cut some pieces of the orange rubber cap to make it fit above the switch and white spacer.
Below you find the photos of how the light is composed in the tailcap.
Also, a justification of my options: Due to the “architecture” of the tailcap, shaped for a tall and fat forward clicky switch, and due to the diameter of the PCB, I will not use a Reverse Clicky Switch (lighted or not) in this flashlight . You can compare how different they are below. Also, I will not bypass the spring. The 4 Samsung or Luxeon will already drain a lot of juice from the cell, so I will avoid more power drain!
For those wondering about the wood piece, here’s a glimpse of what I want
BTW, the clip used in the flashlight is not the one I will use for the final mod.
And here is part of the reason why I will want the wood support !
The rubber tailcap doesn’t allow the flashlight to tailstand correctly, so, putting it into a “hole” will help to maintain it in “candle” position when needed!
Also, I will use a white cap from a liquid yoghurt to make a diffuser when I want to put the flashlight into the wood structure uspside down
It will act like a “lantern” instead of a candle.
