Maximum beam intensity with lenses.
inspired by : "The LOUDENER" 4km ANSI, 230mm fresnel mod for Convoy C8+/M21A
I was playing around a bit with some high-power emitters and different lenses, and I was wondering how one could possibly optimize the LED and lens to achieve the highest possible luminous intensity and the smallest beam divergence.
Basically, something like a “laser,” but thicker.
The longer the focal length, the lower the divergence. However, less light from the LED’s LES will hit the lens.
So, I could put a second lens with a short focal length in front of the LED, but this would make the LED’s LES appear larger. On the other hand, maybe I wouldn’t lose as much light.
How would i optimize for this?
what is the limit?
Saabluster used to build some relatively crazy lens based throwers with the photonic light harnessing reflectors. Look up the DEFT-X
These two objectives are not equivalent, as your focal length example has shown. Since beam divergence can be made arbitrarily small without improving intensity, it is not an interesting quantity to optimize. More interesting is the problem of optimizing intensity.
The Brightness Theorem gives a fundamental limit on how much intensity is achievable, as a function of (1) luminance of emitting source, and (2) size of optic. At the moment LEDs are capped in luminance by about 200cd/mm^2. Multiply this to the frontal area of your lens to obtain a limit on achievable candela.
If you can get your hands on a hemispherical reflector (commonly called “Wavien collar”), you can increase the luminance at the source (to the order of 400cd/mm^2). In comparison, LEPs easily achieve over 1000cd/mm^2.
A precollimator lens has been an idea for a while; I’ve used it to improve collection efficiency in a very old build. I’m actually working on an upgraded version of this build for November, so hopefully I’ll be able to provide more insight then.
Under ideal conditions, adding a pre-collimator lens, while increasing output and beam thickness, cannot gain you additional intensity–the extra lens does nothing to violate the Brightness Theorem, but instead introduces reflective losses. However, since real-life lenses are imperfect (manufacturing deviation, chromatic aberration, etc.), sometimes adding a precollimator can enlarge the virtual image enough to offset some of this imperfection and get a tiny bit more throw than without the precollimator.
Thanks for clarifying!
if Beam divergence can be made arbitrarily small without improving intensity it is only goal becuase i think a low divergence beam looks cool.
On the other hand there must be a limit of how high the Beam divergence can be before i loose “light” and therefore “brightness” ?
If i get this right.
Looking at / in the LED i see the “Brightness” (cd/m2) of the led. but this can never change (with an ideal lossless ) optic.
If put a lens in front of the led i might make the led appear “bigger” or smaller nut not brighter.
for a black body this upper limit of is maybe 340cm/mm² and for a 6600k it is 3300cm/mm²
so even with a LEP there is not chance of coming even closes to sunlight (1700-4000cd/mm²) ?
So if i only optimize for “intensity” if i have an “infinity” big Lens or reflector at the limit i would have the same intensity at the Target as i have right at the surface of the LED?
But only if i focus to a point. but in my cases want to focus at infinity.??
Agreed about the first! I once saw a very old S2+ mod that produced a beam about 1cm wide at a distance of 1m, about 0.6 degrees. It produced an intensity about 50kcd, which a modern S6 SFT25R can easily do, but was nevertheless a very cool piece.
To check if I understood your question correctly: for a fixed LED and a fixed optic diameter, you conjecture that there’s some limit to how tight a beam can be before it loses total brightness? This is true and follows from the Conservation of Etendue, which roughly states that for a uniformly-bright beam, the product
(apparent area of emitting source)*(beam coverage)
cannot decrease through an ideal optical system. Once the LED (i.e., total brightness) and optic size (i.e., apparent area) are fixed, making beam coverage very small would entail making the product very small, which is impossible through an ideal optical system. Thus it must mean that the optical system is not ideal, i.e., a large amount of light is lost. This is what happens for Fresnel lenses with very long focal length relative to diameter: most of the LED’s emission misses the lens entirely.
Precisely!
I’m not super knowledgeable about the luminance of blackbody radiators, but can derive an estimate for the Sun as viewed from Earth. Suppose the Sun has an angular diameter of 0.5 degrees (8.7 mrad), puts a maximum of 120,000 lux on the ground, and has a uniformly bright emitting surface.
Now imagine an emitter 1m away that shines with the intensity and luminance of the Sun. At 1m away, an object needs to be 8.7mm across to subtend an angle of 8.7mrad. Such an object radiates 120,000 lux@1m from an area of 60mm^2, which comes out to a luminance of 2000cd/mm^2.
In comparison, the NLightD X1 LEP puts out 7.55Mcd out of a ~74mm lens, which comes out to 1755cd/mm^2. It gets pretty close!
I think that’s right! An infinitely big lens would take up a whole hemisphere in your field of view, which is the same angle subtended by the bare emitter if you were an infinitely small observer on its surface. So if the lens succeeds in directing light at you without losing luminance, you would receive the same amount of light as standing on the surface of the bare emitter.
In fact, the reflector needs not be infinite: an elliptical reflector with the LED and target at the two foci, or a pair of parabolic reflectors facing each other, would do just fine. For this reason, if you get a spare parabolic reflector and put it in front of a thrower, you can start a fire at its focus.
Focused at infinity, it’s harder to discuss an infinitely large lens because you run into two infinities fighting each other, which is not mathematically well-posed. But if you are content with a finitely large lens, then focusing to infinity gives you a beam whose illuminance (lux on target) stays roughly constant from point-blank to a certain distance, and then beyond this distance, drops off according to the inverse-square law.
@QReciprocity42
thanes! as always your insight was super helpful and i thing you did understand me right.
You are right.
@QReciprocity42 Based on this i was the meat proxy for this tool:
Not sure how good or accurate it is… but its a nice and easy to to visualize a simple optical system.
I would appropriate if you give it a try
I haven’t gotten a chance to play with this tool in depth, but at first glance it looks very interesting and useful. I’ll need to spend more time on it to evaluate accuracy.
Do you happen to have some written documentation of the tool, and the formulas used behind the calculations?
It’s basically a Claude Sonnet 5.5 one shot.
Used about 1 Day worth of free tokens
Summary
i want a 2d simulator for optical designs to play with and understand “Etendue” and conservation of irradiance…
the problem im trying to get an intuitive understanding of is i want a LED light collimated as close to a straight beam as possible with reasonable efficiency and highest possible intensity.
Assume my LED is a Lambertian radiator. the LED has some optical power output or lumen, from a given diameter (size mm²).
i want the highest possible intensity. ideally as intense as real sunlight.
now if i make the lens bigger the beam gets bigger (mm²) and i need more light power from the LED to get the same lux?
but if i make the lens smaller maybe some of the light from the LED is not even hitting the lens and is lost.
what is the ideal focal length for a given LED lens diameter?
and so on.. waht and how many lenses to use ideally?
make a tool to experiment with this interactively and graphically
Beam intensity (cd) is only a function of the source surface brightness, the front area of your final optic, and efficiency of the whole stack.
Changing the optical configuration (eg. with a precollimator) can increase lumen collection at the expense of a higher divergence beam, and no change to intensity.
The only optic which increases beam intensity without making a larger spot size and larger beam divergence is a wavien collar, because it doesn’t actually interact with the beam, it only makes the apparent source surface brightness higher by recycling light that would have otherwise been lost.
So basically you just have to pick the highest intensity source you can, and the largest optic you can, and the rest is just efficiency vs beam divergence.
If you’re not looking into LEP and you only want to use LED, these are your options to get the highest source intensity:
  • Pick an LED with very high intensity to start with (eg. black flat, white flat, ylx, yinding 5050, etc)
  • Put the highest performance cooling you can find (large PC heatsink, liquid cooler, or even TEC if you know how those work)
  • Increase the LED current as much as possible, use a luxmeter and variable power supply to find the peak of the curve
  • Add a wavien collar if you can find one, or get one custom made for a few thousand dollars
  • Possibly point a blue laser at the LED die, but this is kind of turning it into an LEP then
