Maybe not a mod yet, maybe just a thought. Nope, it's not a mod. Cancelled
Just a possibility at the moment. It's a go now. Nope, it's just an idea that did not turn out.
2dn1a
A "D" Maglite, (?Soon to be 1/2 D - 2x16340 IMR parallel? - or just a single 26650 1D).
A Frosted Aspheric.
15 Nichia 119 leds, (maybe 500mA each?).
A couple copper discs.
A crazy person at the wheel.
Nurse, More Pills Please!!Yell
The Nichia 119s were sent to me by another member here. He sent a bunch of them and after the fiasco this morning, I am glad he did.
n1191a
First off, I cut out the larger copper disc. I drilled a hole in the center and then I used the dremel #115 bit and opened up that hole, till it allowed for the smaller disc to fit inside without touching. Then I marked where the leds would go and I filed flats on the edge of the smaller center disc. The flats were to help the led pads line up better with the disc.
n1191b
Then I tinned the leds fairly heavily. I did not tin the copper. I just fluxed the heck out of it.
n1191d
My first try was with a thin aluminum plate under the discs. I used double sided kapton tape to hold the discs in place and I thought I would be able to heat the aluminum from below. That was the fiasco. The aluminum plate warped like crazy and before I could do much, the solder melted and cooled again, so when it cooled, the aluminum went back into normal shape and flexed everything enough that most of the led substrates cracked. It was a horrible sound of death...
n1191e
Good thing there were more of the leds. The second attempt was with a copper bar under the discs and three pair of vise grips holding the discs in place. This is what I should have done the first time, but I was trying to cut corners and ended up shooting myself in the foot, so to speak. This attempt was much more successful.
n1191f
It lives! I tested with 3xAA Alkalines in a plastic holder. It works great and now I can move on to the rest of the build.
There's a lot to do. I will need to cut down the Maglite, decide on what type of switch I want, fit the led plate into the head, make a heat sink, etc....... It will be a few days, but the hardest part is done. Getting those 15 leds aligned was very stressful, especially after screwing up the first batch.
Update - I decided to run wires to this thing and just fire it off direct, with the lens on top, to see what it would be like. It's terrible. Very dim, even DD with a 26650. The frosted aspheric really kills the output by a massive amount. With the lens off, the thing is darned bright, but with it on, it's more like a nite light.
Just not my cup of tea. I am glad I did this first. This way I can still use the 2D for some other build, since I did not cut it up yet.
i like that idea... maybe a few more of them lil nichias though
watching this one
Well.... we know about that next to the last statement. Surprised
Whats that bezel off of?? Do It... I should be able to see it light up from here!!
Dan
The bezel was given to me, along with the lens. It's a stainless bezel, I believe and I think it was made by someone from over at CPF.
How would you wire the nichias?
just sell it to me right now as is :slight_smile:
The two copper discs are the wires. The bigger one has to be cut, so it’s like a large washer and the smaller one just clears in the center, with a gap all the way around. All the negative terminals on the outside and all the positive on the inside. A wire from each copper disc and it’s ready to go, except a backing plate of alminum, with a layer of AA in between, so the copper discs do not short out.
Great!
Even me as an complete idiot in electric stuff can understand this method, it is so simple and yet so genius.
Using this method you can arrange any emitter you want direct mounted.
The reason this works with the 119 is because it only has two pads. It has no center pad, just positive and negative. With a center pad it would be much harder.
Now that you mentioned it, I can remember that cree emitters uses 3 pads (I reflowed an XM-L once).
I wonder about other companies like SeoulSemiConductors or Luminus and their emitters?
But this is going off topic now……
The little XQD's also only have 2 pads, with a max of 700mA and 231? lumens, they'd also be good candidates for a mod like this. I am working on one using 6 on a triple Noctigon. Should make some 1200 lumens on 4A.
Should be interesting to see how that frosted Aspheric handles all those Nichias...
Nice looking piece of work.
Dan.
I’ve tested it out and it’s very interesting. Let’s say you hold the led, (I used a Nichia 219), close to one side of the lens and about 15mm below it. A small spot shows up on the other side of the lens, so there probably will be 15 distinct spots around the outer edge of the lens. It should be fairly strange and unique at the same time. Either that, or with 15 of them, it will just be one smudged ring around the lensLaughing
Well done, can hardly wait to see it working. :slight_smile:
This will make an interesting Light !
More photos in the OP, it's a go now!
