Hi, possibly a dumb question, but in trying to figure out the overall ground path in my flashlight, I’m wondering if the actual - ground pad on the mcpcb itself can contact the pill without issue? Like if in soldering the negative lead to the mcpcb, you grounded (or shorted, if the answer is no) the lead to the pill as well as to the (-) pad. In this case its a brass pill, KD light dtp board and an ld-40 buck driver. I know if the (+) pad/wire is shorted to the pill it will obviously malfunction, but if the negative pad is grounded or touches the pill, will this effect the modes or functionality of the driver? Is shorting the negative pad just the same as shorting the positive pad? Just curious because I know the driver is grounded to the pill in almost all cases, but didn’t know if this was the “same” ground so to speak that attached to the pads that are connected to the LED itself on the mcpcb since these are “ahead” of the driver/pill grounds. Hope this makes sense. Thanks for the insight.
LED - is separate from ground. If you put LED - to ground, you will generally get direct drive, effectively bypassing the driver.
Thanks very much, exactly the answer I needed.
