Measuring Lumens, Lux, KCD, and intensity.
I have almost completed my Integrated Light Sphere, and been playing with calibrations, adjustments, etc with it. Also been reading up on the various methods of measuring Lumens, Lux, kcd, etc of various light sources from flashlights, to flood lights, to household lighting.
There are a number of interesting set-ups out there and contraptions for the evaluation of the incoherent photon.
I seen so many others here using different methods of measuring the kcd, lux, lumens all that from their lights, What are your favourite or most accurate methods of measuring the output of your lights ?
rdrfronty is certainly one of the leading experts here in measuring, measurement techniques, and shear volume of lights measured. I really like his research of distance tests for throw measurements. What's cool is he's got access to a fairly large # of ANSI rated lights, so has a strong foundation for calibrating his equipment. Maybe for tech knowledge, selfbuilt might have an advantage, plus I believe he has a NIST calibrated meter, the same meter rdrfronty has, an Extech I think, but selfbuilt's is NIST calibrated. I know the calibration is expensive, and should be done periodically, like yearly I think. selfbuilt though is not very active here.
I probably have too much faith in my meter, lightbox, and methods, overly so. I do see variations at times I can't explain, but the variations may have a scientific explanation none the less, such as room or equipment temperature, variations in the batteries, lack of consistency in the setup or method I'm not seeing, etc.
I am doing much the same calibration methods of my sphere using all the best and most accurate ANSI-rated lights i have in my arsenal, ( all my stock Nitecores, Olights, Fenixes, etc. )
i thought about contacting a friend of mine who works at a local University where they have a scientific Integrated sphere to bring my contraption to compare and work out measuring values from measurements of a select number of my lights in the Lab sphere then to my home-built sphere.
