Mecarmy new Dual (Teeterboard) Switch, USB Rechargeable Compact Angle lights.
Dual Switch (Teeterboard switch) USB Rechargeable Compact Flashlight
· Dual switch Compact flashlight with USB rechargeable function
· Uses CREE XPL-Hi V3 LED, lifespan up to 50,000 hours
· Momentary ON function
· Instant access to Turbo/ Strobe
· Quick charge in just 90 minutes
· Standard Micro USB Charging port, charges on any USB port
· Charging and fully charged indicators
· Magnetic tailcap provides versatile hands free operation
· Detachable clip
· Over-heat protection to avoid high-temperature of the surface
· Rugged pineapple texture for grip and anti-roll
· Constructed from aero grade HAIII hard-anodized aluminum alloy
· IPX-8 water resistance
LED: CREE XPL-Hi V3 LED
Dimensions:
FM16: Length 99.2mm x Head 29.2mmx Body 23.3mm
Length 3.905” x Head 1.149”x Body 0.917”
FM18: Length 133.2mm x Head 29.2mm x Body 23.3mm
Length 5.244” x Head 1.149”x Body 0.917”
Charging: Micro USB rechargeable, with red/green charging indicators
Accessories:
FM16: User manual, 1*16340 Battery, O-ring, lanyard, USB cable
FM18: User manual, 1*18650 Battery, O-ring, lanyard, USB cable
Notes: The 18350 battery here we mean traction battary like IMR, INR. Which will have higher output than normal 18650
Our international dealers will receive all new items around 15th-20th December.
I’d really like to see a video showing how that switch works.
Will the cells be included?
amazing ingenuity!
Lumens numbers seems not correct why less brightness with one 18650 than one 18350?
How bout offering the FM186 version with both tubes included in one light package?
At least offer the 18350 tube separately.
Can I position the clip free around the tube or is it in a fixed position?
Yes you can
Hi Paul,
Accessories:
Sure
http://youtube.com/watch?v=n5roIaXXfeA
I’ve had good experiences with the FM16 so far. I like the quick access to Turbo. I can carry the lamp in the insert jacket without taking away a lot of space. I have tried the operation with Thl-gloves, works in any case. The FM16 has a lot of power for her size. I could not say anything negative now.
There is even a magnet on the tailcap, but in my opinion it should be a little bit stronger. The rocker switch is easy to operate. I like the little part very well.
