Reading how it works, seems interesting although if you are just looking for something better than thermal grease they already have gallium based TIMs which work much better than traditional grease based compounds. I’ve used some a few times but I find it’s use is pretty limited because the gallium softens aluminum. Since they show it being used on an aluminum heatsink it sounds like that glue resolves that issue maybe because of the much smaller amounts of gallium and presumably some carrier material. But what are the chances this ends up like all those magical battery technologies, vaporware.
I’ve use conductive silver epoxy for making the low-current electrical connection from an e-switch wire to the body tube of a flashlight. Works great and solves the problem of being unable to solder to aluminum. However, when I tried to use it to replace solder for the main ground connection the results were less than spectacular. Light definitely didn’t run as well as with solder.
To me, this sounds actually more difficult than soldering on small components. Solder has the amazing capacity to wet and flow there you want it, I doubt this will do that. I can see some situations where it would be very helpful though.
