[quote=komeko]
Those are outstanding comparisons! Did you use Daylight white balance?
I suggest you be sure to either specify daylight white balance in a single beam photo
or if you use auto white balance, shoot 3 beams at a time, so there is relative difference to compare. One of the 3 beams needs to be CW so the camera sets its white balance to it.
fwiw, even very yellow beams, during the day, will look fine when your brain is adapted to full darkness, or to incandescent light (3000k). And, one of the easiest ways to figure out if your light is 3000k, is to shine it on a ceiling, next to an incandescent lamp.
