Micro mags for sale.ALL SOLD
Up for sale are several micro mags I built about a year ago. I prefer to make my micro mags by cutting the center of the tube and connecting it to the forward threads via the human lathe method. I do it this way because I prefer to have some smooth tube near the tailcap before getting into the knurling. The seam is hidden under the head and I really think the flashlight has a more balanced look with the knurling in the center of the light. The o-ring groove by the forward threads is left intact. All my lights see use including the three below so they are not perfectly polished shelf queens.
The first light for sale is a cut down black LED mini mag. The inside of the head has been drilled out to receive a ¾” diameter aluminum heatsink. The head would probably have to be cut a little deeper to fit a p60 pill. The guts consist of a hand made aluminum pill topped with an XM-L U2 1C emitter and driven with a standard nanjg 105C plus two 7135 chips for 3.5 amps. The driver is set for L-M-H and is glued to the bottom of the solid pill. The emitter can be fully driven with an IMR 14500 battery (not included). Negative contact with the tube is made via a copper ring stacked on top of the 7135 chips and soldered to the driver negative. The pill is wrapped in aluminum strips for a tight press fit. The TIR optic is the clear 15 degree from Fasttech.
Light number two is a cut down silver incan mini mag. The head has been drilled to accept p60 pills. The guts are a handmade aluminum pill topped with an XP-G2 R5 and driven to 2.28 amps with a Q-lite 105c(minus two 7135 chips) set to 4 mode (Moon-Low-Med-High). Negative contact is achieved via two copper tabs resting on the 7135 chips and soldered to the driver negative. The emitter can be fully driven with an IMR 14500 battery (not included). The TIR optic is the clear 15 degree from Fasttech.
Light three is a blue micro mag sporting a stripped and polished body tube. To be honest I let the tube sit in the drain cleaner too long so the non knurled part of the tube is not perfectly smooth. The head is drilled to accept p60 pills. The guts are a p60 pill topped with an XP-G2 R5 emitter driven by Fasttech’s 800ma boost driver. The TIR optics are a floody 30 degree frosted from Fasttech. This light is designed to be used with an AA battery in the 1.2 – 1.8 volt range. It can be used with 2 AA in a standard mini mag tube as well(not included). Fasttech does not suggest using 4.2 volt l-ion rechargable batteries with this driver. I have done it with both the single mode and 5 mode version with no noticeable effects other than a brighter flashlight. Proceed with 4.2 volts at your own risk.
Price is $50.00 each for lights one or two. Light three is $30. Shipping within CONUS is included in the price. International buyers will pay actual shipping minus the cost of CONUS shipping. First thread response of “I’ll take it” followed by an IM gets the light. Please indicate the light you want by color. Payment will be via Paypal.
Thanks for looking,
Brian
Put me in for light #1.
Ricflair,
The black micro mag is yours. PM returned.
Thanks,
Brian
Does Micro Mag #3 come with a single mode boost driver? Thanks.
I’ll take the blue one please. PM me sent, got payment ready.
…If blue is unavailable, I guess I’ll take the grey one.
Hi Slim,
Yes, it has this driver in it. https://www.fasttech.com/products/1127402
Brian
Edeekeos,
The blue one is yours, PM returned,
Thanks,
Brian
Cool; if someone wanted modes then they could use the Nite-Ize IQ switch. Congrats on the sale and to the buyers. These look really sweet!
Not to derail your thread but I think the Walmarts in Falmouth and Scarborough stopped stocking incand Minis. The flashlight sections at those stores are perpetually a trainwreck so I hope I’m wrong.
Hi Slim,
The Oxford Walmart had all the mags I wanted until about November. After Christmas and the ice storm panic the racks are nearly bare. Here's hoping they restock in a hurry!
KY
