I’m really surprised that it hasn’t been mentioned on this forum, unless there is an alternate brand name for it.
About 2 months ago I was in Ho Chi Minh city, and I came across this in a store. It is one impressive looking piece of art, although it wasn’t on my Radar at the time and still isn’t at the moment, but seeing some recent posts on the Trustfire X6 SST-90 I just had to bring it up, as side by side this thing at least looked a lot more impressive.
If anyone’s interested I may even be able to get some information from my local dealer.
1. Use luminus SST-90 LED ( Complete use WN Top gear LED ), brightness reaches as high as 1800 Above lumen, LED The life is 60,000 Hour.
2. Outer covering material: Aviation aluminum alloy T6061-T6 . Surface treatment: CNC The machine-finishing, the third-level black flinty oxidation, oxidized film thickness is bigger than 50μm , skin hardness HV400 , antiskid wearable, the corrosion preventing is good. Armored glass lens. Rear part pressed key type switch.
3. 43 constant flow driving circuit belt remembered, 60 The temperature protection (ultra warm changes over to low bright files automatically), battery voltage insufficient reminder, working voltage: 6-12V .
(1) Glare files position : Operating current 7 000mA
(2) Light files position : Operating current 35 00mA
(3) Weak light files position : Operating current 7 00mA
(4) The storm dodges
4. Condensation system : Aluminum nature refacing reflection cup.
5. Size : 258mm ( Long )*65mm( Forehead diameter )*34mm( Tube body diameter ) , weight : 800g (does not contain battery).
6. Uses two 26650 Charge lithium battery, glare files position cruise duration 45 Minute.
7. Waterproofing: Life waterproofing, against heavy rain (, but please do not soak in water).
Ok, this tabao ad gets my vote for the best translation:
Is suitable the environment: Carries daily
Is suitable the environment: Camping
Is suitable the environment: On foot
Is suitable the environment: The night rides
Is suitable the environment: Searches the hole
Is suitable the environment: Going hunting
And especially:
With tears sacrifice sale promotion!! Because the shop owner works busily, handles Taobao incapable really, therefore the plan endured suffering loses money the markdown sale with tears! ...
...Buys the most satisfied pony roll with the least money, in this time this place, brothers do not miss!
You heard him brothers! Somebody go out and buy this pony roll!
This pony roll (Ha!!!)looks like a light called Flydragon,they had massive aspheric heads and used sst-90 in their lights.HKE used to sell them,not sure if they still do.And dry your tears poor taobao agent,better days are coming!
I find this host strangely attractive. I wish they had made it a big head thrower instead of this little itty bitty head though. It seems the size of head is relative to led surface area is like a P60 with an Cree XP-G.
Could throw nicely through sheer lumen output. But I'd expect floody though.
It’s got a 65mm head according to this dealer. When I saw the thing in store it was a real heavy chunk of a beast, certainly not comparative in anyway to a P60. Here’s an image front on:
I’ve just asked my local dealer for some more information
O.K, my local dealer has confirmed the reflector size is 4.5cm (diameter) by 5cm deep. Tail cap draw 5.3A on 2 x full charged 26650 batteries, he things around 8-9A to the emitter?
I’ll see if it has an aspheric lense and how it compares for throw against the trustfire X6
O.k, this one doesn’t have an aspherix lense. According to my dealer it’s better built than the trustfire X6, brighter and more floodier, and obviously not as throwy.
“If that’s the case, the TF X100 would be quite a bit better. (of course that bugger is also quite a bit bigger and uglier but i guess much cheaper)”
Really depends on what you want, I liken this thing to a monster version of a shadow JM07 pro. It’s not a monster thrower or flooder, but somewhere in between, an all-round monster light if you like. And perhaps a little unique, as there ins’t much else like it on the market and very hard to find.
This Taobao dealer (not the dealer I’m dealing with) as per link has it for $108, not cheap, but not super expensive like the dragonfly
