chadvone
(chadvone)
14
FW3A ??
With a few mods & a little care the D4 can be edc worthy.
What saved my D4.
1. cutting the nub off the bottom of the switch boot. Makes it a little harder to activate but reduces pocket activation some.
2. clip orientation. Basically point the switch somewhere its less likely to get pressed.
Above 2 things helped greatly with pocket activation. I am at zero after several days carry.
I have also done a driver swap and UI adjustments to give 500ish regulated lumens at the ceiling. And lockout uses the last light level. I have a 70ish lumens white momentary (squeeze light), for those short needs. Having to tail cap lockout a EDC light is just wrong.
