After putting off buying one of these many a time I couldn’t say no when it popped up at $14 a while back
1st impressions
It’s nicer in the flesh than I was expecting, finish is decent but there are a few small nicks on the 2 battery tubes
All the threads are lubed, a bit too much lube if anything and all bits have o rings, tail cap having both but the head end of the battery tube only have 1 of the 2 slots populated
Head disassembled
Driver is this and seems to be consistent with what others have received for this SKU
No memory mode but does at least start in high
mode sequence is High-Medium-Low-Strobe-SOS
with the screw you can see in the above shot removed the reflector is detached and we find the 3 LEDs wired in parallel with fairly thin wires.
disappointingly output is quite low with tail cap readings in stock config at 1.6A, which has it being beaten by my darth quite easily and that’s not exactly that bright for a 3 XM-L’er so I had to do something about that.
So I -
Changed the wires to 24awg
Cleaned the domes which had thermal goop on them
Changed the driver for this proper 3t6 one
New driver
tail cap readings after tinkering are 2A :~ so still a bit low, guess it now needs a resistor mod.
And on that subject here’s the relevant resistors, so what do I need to up it to say 3amp
