mixing protected and unprotected batteries in 1 flashlight?
Can I remove a protecion circuit from 1 battery to make it unprotected( and thus shorter) and use it in a series with 2 protected batteries?
I have a TR J18 flashlight and I use 3x 26650 GTL batteries from DX. http://www.dx.com/p/gtl-rechargeable-3-7v-5800mah-26650-lithium-battery-w-protection-circuit-module-brown-2-pcs-182286#.U9LY3Pl_tYU
they are junk, but I had not known it before I bought 8 of them…
They are protected and when I use them in a 3s configuration ( I use 3 batteries in the flashlight) they are a bit too long and the tail cap needs to be screwed really tight to screw it completely. This does not happen when they are just 2.
Do not tell me to use just 2 of them or not to tighten the tail cap, they are too weak to be used in pairs and the flashlight has some play ( very little play) between the pieces when I do not tighten it completely
I do not want to do any mods on the flashlight, but I need to gain a millimeter or 2, because aluminum on the threads at the tailcap is starting to show signs of wear, so I want to remove 1 protection circuit and use the battery with two other unprotected.
Is it OK?
the flashlight is not modded, it does not need high currents, so the protection of 2 other batteries should protect somehow the third one when they are in a series right?
thanks for any advice.
I think its not safe…
+1 Dont do it.
I take that, but is there any explanation?
Why 2 protected will not protect an unprotected battery? They are in a series, if a protected battery does not “let” current flow, there will not be any current running through the electric circuit connected in a series. These batteries have the same age, same number of cycles and the same capacity. I measure their capacity everytime I charge them. The current draw does not change, they all have to deliver the same current. They all have the same voltage after and before charging. 4,2 charged and 3,4 discharged.
Do I miss something?
I have been running RC cars with Li-po and Li-ion batteries of MUCH higher capacities, voltage, and currents for years, and none of these RC batteries is protected. And the cars I run them in pull well over 100A in surges. They are in a different format, but the technology is the same. The Same chemistry, nominal voltage etc… Currents in spikes are regularly 100+ A, and as long as you do not over/under charge or puncture, they are OK.
What happens to an unprotected cell if it is between 2 protected cells?
Please explain it to me as to an adult intelligent man with some scientific background, I will be glad to learn the physics behind it.
The cell without protection may discharge differently and it won’t be protected from over discharge. This shouldn’t be a problem if you are using the same cells (charge, charge cycles and age). Short circuit of the string will be protected (should be if internal resistance of remaining cells is not too high to make it act as a load) by the remaining PCBs and in this case there is no big reason of leaving more than one PCB (you still have to ensure the same charge state of the cells and more PCBs just add resistance to circuit). If you are OK with it, I don’t see any other problem with it.
Jinými slovy - ochranné obvody brání přebíjení, podvybití a zkratu každého z článků.
nope…don’t do it
There are special procedures for mating multiple cells together (series or in parallel)
Common practice for safety the safety minded
A. Matched pair (same battery, same mAh value, same manufacturer and lot if possible)
B. Kept together (charged and discharged together so they are kept at the same charge/discharge cycles)
C. Charge together (to the same electrical voltage or as close as possible) and rotate them in the device if possible (battery 1 on top one time, then on bottom, swap em back and forth to ensure they age together evenly)
D. NEVER EVER EVER mix different chemistry batteries and or different level charge batteries (don’t put a fresh charge battery on a used battery because they will try to equalize charge and the current flow between them can be VERY large until equalization occurs)
Be careful…Li Ion batteries are very high energy density, and that makes them a bit temperamental and sensitive…over stressing them can increase the chances of a vent…and due to the energy density venting can be somewhat violent
If you need a few extra mm, you can build a spacer, get some washers that are approx the diameter of the battery and place them on the - end of the entire cell, be advised due to the changing of materials it can create high resistance connections reducing the overall voltage delivery capability of the device, NEVER put a spacer that can shift and possibly short on the + end of the cell because as mentioned it can shift, short and create a hard short, hard short on Li Ion w/o protection cells can quickly cause overheating and overheating causes a violent vent
same cells and charge. Id do it being more carefull not to run them low.
WarHawk-AVG- I always do what you say about the chemistry, cycles, matching, and using the same cells in the same set. Always!
the problem is my flashlight is slightly shorter for these batteries, and I need 2mm or so to fix it. Otherwise the threads just wear off.
I cant use a spacer, it will only make things worse! I need to somehow make the batteries shorter, and since they are all protected, I want to remove 1 protection circuit to get rid of the extra length, thus making 1unprotected cell in a series with 2 remaining protected cells that are identical in every aspect.
I dont want to remove all protection circuits, I want some protection against overdischarge as an undervoltage cut-off. I do not rely on the driver
It is highly recommended against removing the protection circuit…is it capable of being done…sure
Kinda like drawing a glock with a finger in the trigger guard, nothing bad should happen, until that one time…
so what is the problem actually? running an unprotected cell together with protected batteries or running unprotected cells as such?
mixing protected and unprotected batteries in 1 flashlight. :p
I kid a little...
The problem is mixing different types of batteries in one flashlight.
you can pat yourself on your back guys, I took your advice and fixed it without messing with the cells.
I think the added resistance from the protection board will cause the batteries to discharge unevenly, so it would be risky to try. Glad you found an alternative solution!
They are in a series, so the resistance anywhere in the circuit has to be overcome by each battery to deliver the amps needed ( correct me if I am wrong), so I do not think its discharge curve would be altered.
The original plan was to find the relatively “strongest” cell with the highest voltage measured right after the cut off, ( yes they are all identical, but after a year of use they have slightly different capacities, no significant differences though, I always pay attention to take a good care of them all) and remove its protection circuit, so that the remaining 2 “weaker” cells with protection would offer a saisfactory level of safety and protection( once again, the differences are not big, just marginal, all cells have very similar parameters, but not the same, like all cells after a period uf use).
But that was not necessary, I managed to file down the brass part at the tail spring, so I gained the necessary 2mm and did not have to mod the cells.
