I have two 18650 batteries that last about 45 mins on a full charge on medium on the 105C, about 1.25A draw, i use one, low indicator comes on, i toss it on the charger and usually it charges in about 1.5-2 hours (4.11V is full charge for this thing), but sometimes it takes 4 hours or more, i can’t explain why, when i take it off the charger it reads 4.11V (which is what fully charged reads) but i assume its in the final CV stage. Any ideas?
I use two batteries, when the first one drains i use the second and when its empty the first is partially charged. This problem happens about 10-20% of the time, not sure if its the same battery each time, it might be but i don’t think so
The battery comes off the charger lukewarm if i take it off after 3-4 hours and not yet charged, if i let it finish then its almost room temp like a normal charge time cycle
It happened again, the charger never turned green, just the red LED about 4 hours later, the battery was almost hot, if i remember correctly the charger is supposed to start with CC and end with CV, correct? So what would happen if it didn’t switch to CV?
