Mod a light for microscopy
Hi,
I am working with very tiny insects ( down to 1-2 mm) under a microscope and therefor I need a very bright focused light. Now I bought a swan´s neck lamp to adjust the direction of light and I want to change the LED which is now around 70 lumen with a brighter one. I would like to have XM-L T6 or something similar bright with focused light around 400 to 500 lumen. The power supply of the swan´s neck lamp says the following: 4 V == 0,75 A, 3 W
Is it possible to mod this lamp with a XM-L T6 or similar bright LED? Which driver do I need (i.e. from DX)? Which Lens to focus and for cooling would you suggest?
Hope this is possible.
Regards
cray
hi cray, welcome to BLF!
my thoughts (as a flashoholic and biologist ) about your question:
When looking at insects under a microscope I'm sure you want to use a light that represents colours very well (i would want that), so at least look at a led that has a neutral tint, not cool white. Or even better use a high CRI led (like the Nichia219, I think that one is extremely suitable for your work, at the 750 mA from the original driver of your lamp the output will be a bit over 200 lumen).
Thinking of how the objects are illuminated, I would perhaps go for a reflector based light instead of a light that collimates the light with a lens, because when using a reflector the light is coming from a broader source so that the shadows are softer.
I would say that the light in the hotspot of a reflector light coming from one 250 lumen led will be bright enough for microscope use. And at the short distance of the illumination the reflector can be small. Perhaps you can use the head of a small flashlight that has the led you want.
the resources here truly amaze me!
ken
