Mod: Fixing a Linear-Driven Sky Ray King: XM-L2s on SinkPads
I ordered a Wallbuys $32 SRK and it arrived this week. It came with the new lower cost linear regulated driver. Total drive current was around 5.6A. My initial cheap-o mod was to simply increase the drive current by resistor mod, and at the same time improve the current path (bigger wires, copper braid on the springs).
Due to a resistor reading error, I thought that my mod was unsuccessful. The stock resistors were 3x 1R0 and one R030 for each emitter channel. I added one R33, thinking I had added an R033. Well, the result was a minor gain in output. Thinking that if an R033 cannot improve the output, I'll just short out the resistors and go direct drive.
Bad idea. This mod was super bright for about two seconds, then... nothing! I smoked all three emitters! Ouch. Well, now I can really improve this one... let's wait for the 16mm SinkPads.
They arrived yesterday, and I had three XM-L2 U2 1C emitters lying around waiting to be reflowed. Yummy!
  • Reflowed emitters on SinkPads
  • Lapped pill surface and stars down to 2000 grit
  • Mixed a little Fujik with silver thermal compound
  • Used spacers from my TR-3T6 (same reflector in both lights) to temporarily center the emitters.
  • Once Fujik took hold, removed heatsink and spacers, put back the insulating disks
  • Wired up with 22ga wires
  • Thermal compound on pill threads
  • Added enough R12 resistors to each emitter circuit to get about 2.9A each (8.7A total). One channel needed three, the other two needed four. YMMV.
  • Closed things back up
  • Pop in four freshly charged Sanyo ZTs
  • BRIGHT!
Now that is one bright light. In fact, this 3x XM-L2 is about as bright as my 5x XM-L YH-X9 ( which is driven at 15A, BTW)
Before (Stock) output: ~1800 lm, dropping to 1600lm after 30 seconds (~5.6A)
After output: 2835 lm, dropping to 2770 lm after 30 seconds (~8.7A)
Throw after mod: 37.8kcd. Not bad for a flooder.
Parasitic drain for this linear driver: 198 uA (negligible for 4x18650)
Very happy with the results here! I initially disliked the idea of a linear driver in this light, but now that I have it working this well, it is growing on me.
Happy Modding! :) searchID8935
Maybe some beamshots someday :wink:
Nice mod! Can’t wait for beamshots.
Yeah, I know the horrible feeling of realization of blown emitters. :slight_smile:
NICE!
Sounds great .
Thanks for sharing .
Nice work. You may have just made the “bad” driver, the good driver. Now, we just need to find a way to reprogram that msu.
Yes, I would like to have Turbo, High, Low, with the same hidden strobe. The jump from high to low right now is too much.
Has anyone ever been able to reprogram the SRK driver?
Short answer: No.
Long answer: A couple people have simply removed the mcu and put in a different one that is more easily programmed.
DrJones has (of course, who else? lol) managed to graft on an ATTiny13, but not pin-compatible so it's mounted on extension wires & enclosed in a little heatshrink envelope.
In playing with mine with the same dinky driver I found that if I took all 3 of the '000' resistors (not-resistors?) and used them in place of the 3 originals, output went to 3.4A. I'm only using one of the 3 channels though as all mine are going to be in parallel, and I don't have any more of the '000's anyway.
MCU's PN# is hidden away on the bottom, I do the fun stuff so you don't have to! I couldn't find a single thing about it anywhere.
The standard SRK processor is a Microchip PIC 12F629.
Great mod Relic38!
I also have the WB SRK, with slightly higher stock current. I though it was not moddable due to the “000” resistors that was already attached.
At least mine had those…
So, could I just add more resistors into the green areas?
Do you have link for suitable resistors?
Great mod, you pushed the SRK to the limit here, and with improved heat performance, nice!
Racer, that is wierd. Maybe the thin wires are holding it back, or the Fets are inferior. Basically, that is how I killed mine. I did have 22ga wires though. Adding resistors will not help. If you try a dead short across the zero ohm, test it with less than full charged cells. Mine took a very short time to die.
I had thought of ordering another one, but not so sure now…
Ill try to upgrade the wires… or maybe start with the wires for one emitter and test that…
My WB SRK was ordered 29.04.2013. Received it 11.05.2013.
See here
and here where I posted the picture of the driver
On mine, output is like a good SRK… 99/100 would be more than pleased with the output… and the heat….
But you know… MOAR LUMENZZ!! J)
On mine with that same driver, and even though after removed the '000' resistors measured 0 ohms, when it was together if I shorted across those 3 parallel resistors the current increased, went actual direct drive. LED I was testing with was still on a cheap aluminum MCPCB and got very bright then started going blue... removed the jumper and it returned to normal of around 2A. It did that on all 3 channels, too.
Measured emitter current:
L1 2,7A
L2 2,6A
L3 2,2A
I measured before and after wire upgrade. Those results are basically start up current. Within about 30 sec they go down about 0,1A. After that still going down, but very very slowly…
As you can see from the emitter currents, its a quite healthy SRK I got. :slight_smile:
Im quite happy with the driver (for a SRK that is), considering that I did not get one of those with 5+ amps total. But would be nice to make it closer to 3A on each emitter. 0:)
Basically, wire upgrade did nothing. Although, it certainly did not hurt. When I took off one of the plastic insulators the wire was on the insulator, not on the mcpcb… :stuck_out_tongue:
That might have improved it a bit…
In comparison. Here are the results from comfychair. I borrowed them from this post.
L1+/L1- 2.20A
L2+/L2- 2.60A
L3+/L3- 2.08A
R86, see if adding a short across the resistor on L3 helps bring it closer to 2.6A. If you can get it balanced, you have real good output there.
I still do not understand why yours needs a short when mine needed resistors. Can you read the part numbers of the FETs, the large chips? I’ll compare to mine when I get a chance.
D436
BA7L15
Same on all of them. You can basically read it in the picture i posted above. I assume that is one of the three FETs… ?? :stuck_out_tongue:
Could it just be variances in Vf between emitters? Or would that not account for that much difference?
