This is a 30mm driver out of a Alonefire BK105 Gladiator. Has anyone had any luck messing with these? I like the size of this light and I think if I get driven properly it will make a nice beater light.
Hi!
I do not know this driver … but R3,R4,R5 seem as sensing resistors, if the dissipation of the LED is correct and if on copper star you could lower the value of the resistors to give more A to the LED ![]()
The low mode is adjustable by holding the button in. I wasn’t sure if the “normal” resistor mods would change that or not.
I considered just piggybacking a new driver but since there is a side switch Idk if that changes anything?
Of course, you would need driver for e-switch.
fair warning: that variety of light has a notorious track record for having a horrible thermal path, so I would check that before you start bumping current.
I would have thought the full shelf would have transferred heat to body rather well.
Maybe I can try using a solder iron on the shelf and see how the transfer goes.
Thanks for the warning, guess it’s something else I need to research.
