Ages back I bought a Crelant V9CS. It was my first light like this. And while it’s nice, it has some obvious issues.
Not all the bright by today’s standards, i.e. very low amp draw on high. And you only get regulation on 2x li-ion, which results in dreadful runtimes.
But the physical quality of the torch is brilliant. So I’d like to spruce it up and update it.
I believe the V9CS is fundamentally the same as the V6CS (which seemed to replace the V9CS).
Is there an easy way to tweak the driver on these?
I’ve not yet pulled it apart, so I don’t know what size driver it uses. Was hoping someone may have done something to one already.
It is a dual switch, rear clicky for on/off and ramping via the side electronic switch. I don’t really like the ramping and would be happy with a normal 2- 4 mode driver.
Not sure how easy it is to retain the side switch for mode selection. But it would be nice if possible.
BTW - I’ve done plenty of Qlite modded torches already including a C8. So while not against doing this, it would be nice to maybe do something different.
