Mod or replace driver ?
This is for a laser sight, old one was great, 100% on and over 5mw… got this new one and its apparently PWM as it flickers about 60%-75% on and 40%-25% off when you move it fast against a wall. Seems most likely 5mw or less.
Question is, is there anything i can do to whats already here to make it 100% on or just replace it ?
I take it the center chip is the PWM… back side has 350ma printed on it..
Been looking at other drivers of about the same size and are able to push more power and some are adjusted.. but they get 3 out of 5 stare or less reviews..
Whats your thoughts ?
Not wanting a burning hot laser just no flicker and a good bit brighter..
I remember laser diodes would have a sensing photodiode for feedback to keep the laser from cooking itself. Pretty much a must, especially for higher power chips.
Seems cheaper ones just don’t do that, and “regulate” the chip open-loop. Or maybe this isn’t a constant current regulator but a bang-bang regulator (pwm).
You ain’t gonna force more output from that diode. At least not for very long. For more output you’d have to just replace the whole thing, better diode+driver.
Yeah i seen the better ones have a sensor up front and wires going back to the driver. This is an $18 one from Amazon..
Picked it as it had external adjustments for windage and elevation.., was able to get the whole unit out, i will replace the whole inner unit once i can find one that will fit..
I was wanting one to point out to others what im about to shoot or for them to shoot what im pointing at.. but it has to be real low light to see it at 100 plus yards or more..
I know the military ones are definitely brighter. And $$$..
depends on the host and what driver is in it now. if it is a convoy or similar the 17mm buck drivers (5a or 8a) are a straight swap and way better than the old linear FET stuff. measure the driver pocket first though — that is the thing that limits what fits. if the original driver still works but you just want a different mode setup, reflashing is often easier than replacing. what light is it? pic of the pill would help.
ah sorry, i replied too fast — thought this was about a flashlight driver. laser sight module is a different thing entirely. for laser drivers, messing with the sense resistor value can adjust output current, but you need to know the driver IC first. post a close-up pic of the driver board? the IC markings tell you what is possible. and be careful — lasers have different safety implications than LEDs, especially above 5mw.
Photo is at the top of this thread.. im in the process of replacing the components, got it took apart, want to replace the lenses from plastic to glass, saved the crystal that makes it green, looking for a more powerful diode and an adjustable driver..
What i “think” i want.. if the driver says 350ma i would assume thats its output.. so a 700ma would be double, i can adjust it down as needed..
3-5v and 700ma…
Like i said, not looking to fry eggs with one, just want movie/military type output for momentary designation of target under all conditions.
5mw is all that can be sold as a working unit.. id guess im looking for a 10-15mw then ? Or does it not have double the output as you double the mw ?
Im just assuming here..
So anything around 10-20mw diode.. 700ma adjustable driver, in the correct dia and stuff of course. Seems simple enough, so i wont expect it to be hahaha
I recently found DTR’s Laser Shop.
Perhaps one of these options would sort you out?
Thank you sir..
