Mod ultrafire 1200 halogen
Hello looking for some info to convert ultrafire th 1200 to a large Cree bulb . Would like to learn
I would not recomment it
main reason is the reflector is not compatible to LED focal pint unless you would saw it off to fit
No heat sinking base for the LED
better get yourself a Convoy C8 host and build a thrower
Ok I’m new to this I know what a convoy c8 light is but what is a host and a thrower ?
Host: Where the light and electronics will sit to provide protection, heat dissapation, switch, etc.
Thrower: Throws light quite far, with a very defined light spot, which is called a hotspot.
Ok so where can I get this stuff ? Still trying to find my way around this sight
Complete light:
https://www.aliexpress.com/item/Black-Convoy-C8-with-XPL-HI-LED-copper-DTP-board-and-ar-coated-inside-new-firmware/32889563626.html
Host(+LED+driver): Convoy C8+ Flashlight Host - Sand
LED: http://kaidomain.com/Flashlight-DIY-and-Tools/LED-Emitters-or-LED-Star-on-PCB/CREE-XP-L-Series-LEDs/Cree-XP-L-HI-V3-3C-Neutral-White-5000K-LED-Emitter
Driver: FET + 7135 Driver - 17mm - MTN-17DDm
18650 cell:
But 4 just in case you need them.
Charger, a very good one in fact. Charges lithium ion 18650s, NiMH AA/AAAs, and even smaller cells:
