M4D_M4X
(M4D M4X)
May 11, 2014, 10:17pm
1
Hey Guys!
I once bought a SK68 Clone (1-Mode) for 3 or 4 Bucks shipped some time ago…
i also ordered 14500 Keeppower from banggood
Build quality is quite bad - the pill is was hollow - so i did some tweaks:
some Copper laying arround…
Cut an file a piece
press-fit to be better than nothing… (height was lined up when i assembled it)
dedomed the XP-E (used a wire to hang the MPCB into a bottle of thinner for 2 hours an blow twice)
soldering back and put some thermal paste (no pic - sry) under the star
with a eneloop:
with 14500:
outdoor eneloop:
outdoor 14500:
my mobile gave me some “Illuminationnumb3rs”
eneloop: 1300
14500: 3400
8)
MRsDNF
(MRsDNF)
May 11, 2014, 10:20pm
2
Very nice. The hot spot and flood appear to be about the same size before and after.
M4D_M4X
(M4D M4X)
May 11, 2014, 10:33pm
3
you are right - should the dedome have more effect?
MRsDNF
(MRsDNF)
May 11, 2014, 10:34pm
4
I've never dedomed a led in a zoomie. Others will chime in.
Nice…like the copper slug
Thinking of putting a XP-G2 in mine and seeing how it handles
(might want to resize your images down to 800x600 or smaller levels)
Better
Really want to wick the heat away…
Get a 16mm copper sinkpad XP-E
direct solder to the slug, then reflow the emitter on that
Alot of work for such a cheap light
I’m attempting to do an OSHPark 5*7135 15mm driver for the SK68…that’s 1750mA max current to emitter [if using 350mA 7135, 1900mA if using the 380mA 7135’s]…plus be able to flash custom firmware to the MCU…still learning under the tutelage of Mattaus (the Eagle MASTAH!)
freeme
(youtube.com/@1thedeals)
July 14, 2014, 4:33am
8
My mod version:
UF-SK68
XP-G2 S2 on noctigon
thin copper slug, cut from copper pipe
60 degree TIR - fixed focus, floodier, no more ugly beam patterns
new o-rings.
All under $10. :bigsmile:
