Just wondering if anyone here has modded a TN30 and what you did?
I have modded my TN31 which was very simple. Just the standard de-dome, replace the resistors with solder, upgraded wires to 18AWG, polished the star and pill and used some AS5 then braided the springs.
Can I do the same sort of mods to a TN30 in particular the resistor mod? I am not sure how this all works with the triple emitter?
I’m not sure if you can bridge the resistors together, but the PCB layout is very similar to the TN31’s and there are two sense resistors you can access.
Make sure you provide good heatsinking between the PCB and the light!
So on my TN31 I pulled the two sense resistors off and just replaced them with a solder blob as from everything I read that’s what most people were doing to push it as hard as possible.
