Modding drivers
Hi all,
I have a quick question about modding drivers for more output as I don’t seem to be able to find the info I’m after.
When using a 4.5v driver, I’ve read a few threads that mentions adding or stacking the 7135 chip for more output. But what I can’t seem to find is the ‘how to’ on modding the higher voltage drivers (The type used for 2x batteries in series)
I’m assuming that the higher voltage driver needs the sense resistor modding as opposed to stacking chips ?
Sorry for the dumb question, it’s probably obvious to most of you.
Thanks
Most high voltage drivers are switch-mode drivers. In Most cases, these have a sense resistor.
Now, before the how, lets cover the “should”… Should you increase current on a switch mode driver.
Switch Mode drivers have several parts in the high current loop. At a minimum, they’ll have a MOSFET, a Schottky Diode and an Inductor. All of these parts are rated for a maximum current that they can withstand. Parts that can handle more current are generally larger and usually more expensive. Ask yourself this; Do you think a chinese driver that cost a buck or two was designed with much headroom on the specifications?
Now, if you still want to go ahead and try it, then yes, you’ll need to modify the sense resistor. This will usually be a low-value resistor (milliohms) right near one of the output wires. Check to be sure there aren’t multiple resistors in parallel or series, and I’ve seen this on many drivers (ie. 3 58mOhm resistors in parallel yields 19.3 mOhms effective).
Once you’ve figured out the complete total of the sense resistor or resistors, you can use simple math to adjust…
For instance, if 19.3mOhms yields 2A of output current then
2*19.3 = 38.6
38.6/3 = 12.86mOhms
changing to a 12.86mOhm resistor or group of resistors would yield 3A of output current.
Don’t say I didn’t warn you though - and don’t be surprised if the driver fails after such a mod.
PPtk
Thanks very much PPtk. Very good in-depth explanation. So it’s all to do with the quality of the components used.
I assume it’s the MOSFET that takes the brunt then ? so perhaps heatsinking the MOSFET would help. Haha, now it makes sense why a lot of manufacturers grind off the information on their MOSFET chips :smiley:
Now all I have to do is find out which MOSFET chips are better than others (evil grin)
They are several drivers that can be modified by changing the sense resistor. Some have components that will stand a little extra voltage or current and some want. The components will determine how well it can handle the modification as already mentioned by PilotPTK. Here is examples of modified drivers here and here. Sometimes even adding PWM with a 555 timer or by way of attiny13.
If you will post up which driver you intend to modify. Maybe someone can help with the modification. :slight_smile:
Thank you for the links and the info, going to have a read now :slight_smile:
