I really like the size with 2 AA. Problem is that it heats up a lot with two AA installed so it becomes uncomfortable to hold.
I am wondering if I can cheaply mod it to have two or more modes? At least one mode with 25-50% brightness (and heat) would be handy. Can I order just new power switch cap that has 2+ modes somewhere? Or can I order some real cheap single AA flashlight with modes and switch the caps? Any hints where to start looking?
and you’ll have to de-solder the original driver and replace it with the above. NOTE that the way the light is designed, the negative contact is via the 2 solder blobs on the edge of the driver board touching the leading edge of the battery tube, so when you replace the driver, you’ll need to also add similar solder blobs, or something else to replace them.
Multiple modes can be done by the driver electronics and the driver board is not usually in the cap (also not in this one), but instead in the head of the flashlight. You can try swapping the driver board by one with multiple modes, but it might be easier to just buy another cheap flashlight, most have multiple modes, the (Fandyfire)C3 is actually an exception to the rule.
The Ultrafire version of the same light you have has five modes:
Can those handle 2 AA? Would the threading of extension fit?
They would only cost 2-3 dollars more (and no soldering) than just the driver and then I would have 2 working flashlights. If both work which one of those would be better or is there something better (but cheap) where extension would fit?
Almost certainly this will not work, every threading is different in chinese flashlights, finding a part of one flashlight that fits on another one is a rare (but happy ) event.
