I’ve noticed some lights like Fandyfire STL-V2 claiming 3000 lumens others on 3 x XML-T6 claiming 4000 lumens.
Is this possible ?, they are using different drivers as the modes are different, if I were to put in the same drivers, or a better/more powerful driver would I get more light, at the expense of runtime I realise, thanks.
tabs
more than likely… what they claim are”chinese lumens” , they usually off by 1000- 3000 lumens ![]()
Fandyfire STL-V2 is really more like 1300 lumens
I assumed some of the claims were OTT, looking on youtubby it’s so hard to tell.
I should maybe satisfied, and I am, with my Fandyfire, but you know how it is, if you can get more why not!!
I’ve now got 4 torches lined up for mods, 2 are bare hosts, 2 others that need a bit of work, 1 fell from 120 feet onto a semi hard/ish surface but still works sort of.
One just has a hopeless reflector, the spot is tiny masses of flood but useless.
I also need to repair a CR123 light, the switch has gone kaputt in the tailcap, and I can’t get the bloody thing out, since I tightened it up too much last time, can’t find spare tail caps anywhere.
