Does anyone still program there own Attiny13 with there own code for flashlight modding.
I occasionally flash Biscotti onto ATTiny13 drivers.
Mostly I’m just getting rid of the 3/5 Firmware.
I still do a few clicky builds here and there and flash firmware onto at13 and at25 mcu’s.
But as I transition mostly to Anduril lights, I do it less often.
yeah still do it. attiny13 is still on a lot of budget drivers, convoy uses them on most of the linear and buck boards. the flash is tiny but for basic mode groups it is enough.
i usually start from jonnyc or toykeeper base code these days instead of writing from zero. saves a ton of time. if you need more flash the attiny85 boards are easy to find and give you more room for extra features. the newer attiny1616 drivers like loneoceans t1616 board are nicer but the register map is different so there is a bit of a learning curve.
what host are you working on? the driver pocket size kind of decides what board fits.
How doable do you think it would be to port Bistro to the attiny 1616? Where should I start? I’ve done a little programming of arduinos etc but nothing this scale. I think modern drivers with Bistro would be fantastic
Thanks for all the answers, Where are getting your driver boards from. If possible could you link to one which can definitely flashed.
If not the At 13 any mcu would be good for me to start.
Thanks again for your help with my new hobby.
Any driver board will do to learn on, Aiming to turn my own Barrells and make my own customed program in the end. Thanks for your previous answer.
Thanks for the link and info. Great support
