Modifying a milwaukee light with xml
Hi, I’m new to modifying but have been reading up the last few months.
I would really appreciate some advice!
I have a 12v torch I use for work (electrician), it was originally an incandescent, I then squeezed an mr16 9w led lamp in which isn’t great.
I’d like to fit a single xml in neutral or warm white with a fairly floody throw.
I was practicing with an old xml and a buck driver. The xml was mounted on an led gu10 heatsink which seemed to keep it fairly cool.
The buck driver however became hot, could still squeeze it in your palm with out it becoming uncomfortable but not sure how it will cope been enclosed in the plastic body of the torch.
I’m also concerned about the heatsink not dispersing heat in the plastic head. I have room for a small 40mmx10mm fan and can drill extra vents but worry about dust killing the fan the allowing the led to overheat.
Is a buck driver the best option or is there a driver for 12v input, 3.5v output? Would love a driver with a high and medium setting, say max and half output.
What reflector would be good? Dia of 47mm depth of about 25mm?
Is xml best option or would 3x xpg under driven be better at keeping cool?
And finally, where is a good place in uk to buy from?
Cheers.
Welcome to BLF !
What’s a milwaukee light?
It’s about current more than about voltage with LEDs.
You must have heard of “constant current” here and there.
Many (chinese) web stores for flashlight parts.
Milwaukee is the brand, it’s a milwaukee m12 which accepts the 12v batteries from cordless drills and other tools.
Aha, I see.
You want it just to turn on and off, or do you want high/mid/low or something?
When you have cooling problems you can also run the XML a little low, say, 1 Ampere.
The problem is it’s all plastic…
You’ll have to replace the reflector with an aluminum one, suited for an XML, and make thermal path to it from the LED base.
Maybe here you can find the right one.
An MR16 (12 Volts) LED lamp should work nicely though, but you say it didn’t…
MR16 drivers are not expensive.
You’ll need something like a 900mA at least.
This one might do the job fine.
You should bypass (remove them or not) the 4 rectifier diodes (They eat 0.6 Volts each and current passes through 2 diodes = 1.2 Volts drop (waste))
This such an indepth project cause of the poor (plastic body, not setup for an LED) “host” you’d probably be better off adapting an existing light to take the 12v driver and having leads from the light’s body to plug into your battery. But I’m guessing the goal here is to have a bright LED light that will run on your power tool’s battery right?
Another choice would be to use a stock LED flashlight with a more common boost driver (runs com a single cell) and then get a step-down converter that fits in the battery compartment of the light and again have leads that come out the end and plug into the battery pack.
Thanks for the replays, I think I’m going to try running the light with a fan blowing through the heatsink fins and hope the fan doesn’t deteriate due to dust.
If it does I’ll have to find current the led is happy to run at with out heat issues.
If I lower the voltage on the buck driver, the current draw drops. Is this the correct way to achieve constant current or do I need a buck driver with current adjust?
