Hi all!
I'm new here, so I wasn't sure if my question belongs here or in the headlamps forum, but since it is about modding and DIY parts, I figured I'd go here :-)
I have both a Silva 478 and a Silva 480 headlamp with 10 and 20 W halogen bulbs. I'd like to keep most of it, but fit something with an XM-L onto it.
The story is that I've been running night-orienteering for 20 years and used one of them the last decade or so. I always felt they gave a lot of light, but nowadays people are fleshing out NOK 6000 or more (~ USD 1000) for a LEDX lamp, with 2500 lumen. The insanity! :-) I once figured I should sell refurbishment kits, but MagicShine has something that sells in local stores for reasonable prices, so I'll drop that. Myself, I figured I need an upgrade, but the Silva 480 headset fits well and is really stable, it should be, it evolved over 40 years or so, I'll keep it... Besides, the NiMH battery that I have should be possible to reuse, it is a 9Ah 6V battery, and it still performs OK.
I'd like to meet or exceed the specification of a Silva XCL headlamp, which means at least 300 lumen and 120 m throw. Shouldn't be too hard, should it?
That's the background. I've been looking around, and it seems to be some nice 52 mm drop-in modules on DX. I think it would be interesting if I could upgrade my headlamp with new drop-ins as they become available. It is not too hard to put together driver, lamp, heatsink and so on, but I usually have little time on my hands, so using drop-in modules seems like a compelling alternative. There are much fewer such drop-ins around than P60 modules, but I figured a P60 can never have more than one LED, can it? So, what options do I have if I want to stick to drop-ins?
Mounting something on the headset seems easy enough. There are two holes 37 mm apart sticking 30 mm out from the headset. I need something to mount with screws between those holes. I always find a lot of flashlights that can take drop-in modules, but units to fasten on the forehead I haven't found. Not too easy to describe something when you don't know what is called, I hope it was clear enough... :-) My next question is: Are you aware of any such things?
Finally, the electrical stuff: I have no specification on my battery regarding the discharge current it can sustain. Am I right in assuming that it can sustain any discharge current if the discharge is slower than the brightest light I used to have? For example: The 20 W halogen bulb would last 2h40mins when the battery was new, so since it is specified at 9Ah, it would be able to supply an XM-L with 3A since that would discharge it in 3 hours? (which again means it would have >3C, right?)
