As I sit here all broken hearted watching my first BLF post proceed, unloved, toward the bottom of the page, my thoughts turn to flashlights. More specifically the flashlights we the enlightened modders build for family, friends, and colleagues who want a bright light but can’t find the strength to embrace more efficient and/or energy dense power options. Alkaline batteries seem to be the darlings of Mainers everywhere and even heavy duty batteries are sometimes the preferred option.
So what are your favorite flashlight recipes for the battery handicapped? Several have been built by me in the past but I will make the first contribution with my newest and current favorite, an honest 500 lumen OTF 2D mag built to run on alkalines. Many of you already know what I did just from the description as it is really nothing new, but I will bore you further anyway.
I started with a pretty blue 2D mag and modded the switch and reflector for an LED upgrade. Next I made a heatsink with a ¾” length of 1-5/16” aluminum rod and added a pedestal of 5/8” aluminum filed down to about 14mm so the beam remains focus able. Drilling a couple holes for wires and a quick hogg out of the bottom to accommodate the driver resulted in a functional heatsink.
The 14 mm XM-L U2-1C emitter was mounted with Arctic Alumina and wired to a 6 chip Nanjg 105c. Unfortunately Fasttech sent the driver with modes chosen with the UI rather than the driver with modes chosen by by soldering stars so there is an unfortunate blink about 5 seconds into low mode. Fasttech has of course resolved the issue to my satisfaction. Again, I bypassed the switch connection on the positive side of the circuit.
Two 3AA battery trays from Kaidomain modded to a 3 in serial by 2 in parallel configuration will keep the batteries from seeing more than 1.05 amps while the emitter gets the full 2.1 amps.
Match’s handy emitter tests indicate a T6 will put out roughly 710 lumens at 2100ma. Add a few percent for the U2 upgrade and minus 30% for reflector/lens losses and the OTF should be around 500 lumens. My crappy camera doesn’t do the light justice. Beam shot is a garage wall at 40 yards.
So what have others done to accommodate friends and family who cannot bear to be parted from the familiar store shelf type batteries?
KY
