The P60 module does indeed breakdown into reflector, pill, and spring. However, I have doubts that the P60 pill will fit in that U4-MCU light. It looks a lot like a C8, which has a different style of pill. Maybe a picture of the the pill you have will help. (post to imgur or photobucket and then use a direct link to it on here).
Also, if we can figure out what is wrong with the light (driver or emitter), it may be fixable without replacing the pill.
the 4th pic on the dx link shows the pill, and it dont look like a p60 or a c8 pill. if you could post a better pic of the pill in your light someone would be able to help you better
With no spring or anything else on that contact board/driver in the back of the pill, I gotta ask, what batteries are you using? Some flat top cells will not make contact on a board like that at all, some are fine, and some will only work when they feel like it...
Ultrafire XSL 18650 2600mAh 3.7V. The positive end …which has the extended contact point …makes contact with the board.
The light worked with these same batts for a long time after I got it. I had dropped the light; thought I had messed up the solder connection …thus the messy job.
Actually, it worked for a spell after the first drop, and a re-solder. Then I dropped it again, and that solder attempt did nothing.
Have you ruled out a problem with the switch? Put it back together and with the tailcap off, jumper the battery negative to the light body with a piece of wire, screwdriver, whatever.
If it's truly dead, send it over and I'll either fix it, or replace all the guts with good stuff. I have lots of spares. XPG2, XML2, copper boards, 3 amp drivers, etc. I'm just across the state line in Meridian MS.
L to R: Convoy S4 ( :love: ), U4-MCU, UF C8. Interesting light, this U4 - fatter battery tube, but slightly smaller head, than a C8. Fat tube means it'll also take a 3xAAA carrier, too, though at pretty reduced output (but still a very usable amount of light). Always nice to have an option to run from more than one battery type in a pinch.
Red Sharpie shows contact between reflector & head, probably better thermal path than a P60. Lots of threads in there, too - pill is about twice the height of a P60 pill:
Reflector is smaller than a C8 at about 35mm, and slightly shallower. Has a real nice soft beam with the XML2; it was awful with a XR-E :Sp
XML2 T6-1C, Sinkpad soldered to pill, 3.04A Qlite set to star #4 for the 20mA-2%-25%-100% group, 22AWG silicone wire.
With an average 2400mAh 18650 it does 1h15m on high... it gets HOT after around 10 minutes, but seems to level out nicely and holds at that temp apparently forever.
(oh, in case anybody's confused what the hell's going on in this thread, BamaPanda sent me this light and a TR-801 for an overhaul... the TR-801 is finished too, just don't have pics of that one yet other than the pill pics in last night's post)
It's a quality cell and has protection. The problem with Ultrafire is unknown quality. It's almost always bad, but it's a question of how bad and risk. They're cheaper, but sometimes the true capacity is so low that it ends up being a worse deal than quality cells.
Layer of solder paste on the pill, lay the Sinkpad in place, apply paste to the LED pads & wire pads, set the LED in place, then do it all in one go with hot air from the butane torch in hot-air-only mode held under the bottom. The layers go off from bottom to top, so it doesn't take more heat to do the pill-to-sinkpad joint than the LED can withstand.
The only trick is, the Sinkpad HAS to start out oversize, and has to be file-fit into the pill so the LED ends up exactly centered with no slack. If it's a loose fit the surface tension of the solder will pull the sinkpad to one side or the other, and you'll never get it right before the LED overheats. And you can't do it in two steps and reflow the LED afterwards, as the joint between sinkpad & pill will remelt before the solder on the LED pads melts.
