Cree XLamp XP-L High Density LED Star
$18.99 CREEXPL-740-3
Board Configuration : Triple 3 Up (+12.00)
Color Temperature : Neutral White 4000K
10510 Carclo Lens - 3-Up Elliptical Spot LED Optic 10510 Carclo Lens - 3-Up Elliptical Spot LED Optic
$1.50
BuckPuck DC LED Drivers BuckPuck DC LED Drivers
$12.82 03021-D-N-1000
Connection : 7-Pin SIP
Dimming : Non-Dimming
Output Current : 1000mA
I could probably save some money by reflowing the LEDs myself but I’ll try it out with something lower risk if you guys know what I mean. I figure by running them at lower current it should be easier to cool. My plan is to modify a 7” sealed beam by cutting out the bulb and sealing in the LED and heatsink assembly. I’ll be testing the parts I’ll be using on the bench to make sure they all work together which is my biggest concern right now. What should I get and use together? Advice is welcome since all I’ve actually done so far is tear down and research.
I can not reflect on how this is going to work on your motorcycle (never had a motorcycle but 1A through a triple will not give you a bucket-load of light) but for the parts you could check out if http://www.mtnelectronics.com has them cheaper. At least the triple board can be had cheaper and thermally better than the one from Ledsupply.
I think you’re right it needs more LEDs to be brighter. I’m not sure how to find good optics though. I need some way to have a cutoff to keep oncoming traffic from being blinded. I plan on using separate lights for high beam which should make it easier.
I’m planning on putting the LED assembly into a old style sealed beam like you would find on a Harley or a old Jeep. The problem is I can’t find a big enough driver to put out 3amps on 12 volts inside of a sealed module.
If you use the sealed beam, will you also use the reflector that comes with it? A reflector for incandescent bulbs do not work well for leds (because leds only emit to one side). But if you go for optics before the leds, like you suggest in your first post, it will be fine.
MT-G2's require a different optic than XP-L's because the led is so big. I'm not aware of the existence of a MT-G2 triple optic, or even a MT-G2 triple board. Oh, and I see now that you wanted to use the 10510 Carclo optic for the XP-L, it will not fit, the domes are too big. That optic will fit on a XP-L Hi led which is domeless.
This is a (mainly) flashlight forum, so you will likely be recommended flashlight parts. And so do I, but since you want to use small parts for your build, flashlight parts may actually be the way to go :-)
How about:
*this triple XP-L Hi : http://www.mtnelectronics.com/index.php?route=product/product&path=60_106&product_id=536 . You will have to ask with the order to have them mounted in series (the default is parallel), so that it will work from 12V (together with the driver). The ledboard must be mounted on a (passive) cooling device made of aluminium or copper, which can dissipate the heat to the air.
*plus this optic: http://www.mtnelectronics.com/index.php?route=product/product&path=68_69&product_id=63
*for the driver, please ask Richard (the owner of Mountain Electronics) for a suitable driver to run a XP-L Hi triple in series at 3A from a 12V motor cycle battery.
This will get you close to 2500 lumen, which should be a fair amount of light for a headlight.
After doing more research I have decided not to do this. The modder simply cannot build a proper cut off to fit the legal requirements, or at least I can’t.
I hate googling and finding incomplete threads so here is a build log I got the idea from
