Mr Lite LT3 driver needed.
Hi guys. I've got a dead LT3 that needs new driver. LED works, tested it with battery (how do you test drivers anyway). I measured it as 18mm across. I would like it to be H-M-L only, emphasis on high.
Any suggestions appreciated.
William
3 mode low, medium and high. The leads are already soldered on which is the hard part because they are so small. Bryan will ship it out first thing Monday morning so you should have it in BC by Friday if the strike doesn't mess it up for you. 1.4 amp high so it will blaze.
http://www.shiningbeam.com/servlet/the-133/3-dsh-Mode-Regulated-Circuit-Board/Detail
