Since we all love MT-G2’s I figured I’d put this up here - a MT-G2 based vehicle spotlight.
This guy:
Here’s the insides:
I don’t have any beam shots at the moment since I’m still putting my bike back together in anticipation of a month-long trip I’m taking, but I did measure the power draw off of a charged 12V AGM battery (measured 12.86V under load) and got a bit over 1.7A so total wattage was about 22W. I also ran it off my bike while idling (14.1V) and measured ~ 1.55A, so still right about 22 watts. I’m presuming it’s providing right at max rated amperage to the MT-G2 (based on what I think are the current sense resistors, I’d say it’s a 6V MT-G2 and it’s getting around 2.8 - 3A) so the LED is getting 18-19W and the rest is being lost to inefficiency. I’ve let the light run for an hour in my garage without any active airflow and it really never got more than warm, plus it supposedly has a thermal throttling function (NTC thermistor between C6 & C7?), so I’m thinking a resistor mod is in order to bump up the amps!
The Linear Technology LT3756-2 and the AOD482 MOSFET can chuck out way more current than the MT-G2 will handle or the enclosure has heat dissipation for, so I’m thinking that they won’t be the limiting factors. I’m struggling to completely make sense of the circuit as it doesn’t follow the LT3756-2 reference circuit and I can’t get a diagram for it, but my guess is that R13 is the current sense resistor. From the LT3756-2 datasheet, if the voltage it’s looking for is 0.1V then the R036 gives 2.78A, if it’s 0.108V then we’re seeing the full 3A we’d want. I don’t see how the R012 could be the current sense resistor as that’d push the current WAY too high.
What do ya’ll think? Am I on the right track or am I way off base? Thanks!
I’d be interested in seeing how they designed their circuit if they didn’t follow the reference. Just having a few part numbers from a commercially built unit sure helps. I’ve been wanting to build my own 3x MTG2 light bar for my suburban, but my EE skills are quite lacking. I figure if I drive mine a bit hotter at 4-5 amps I shouldn’t have any problems with lack of light. :evil:
I’m a bit of a cheapskate, but honestly $100 isn’t too terrible.
In a word, no. I suppose I’d be possible to power a 12V LED (XHP’s, some MK-R’s, maybe others) DD off of an 12V (12.8+ fully charged) AGM battery, but only if it wasn’t connected to any charger. Because all of the lead acid batteries (FLA, AGM, I think gel cells are a maybe a bit lower) charge at 14V+ and you’d burn the LED up, plus if the battery was connected to your vehicle’s charging system there are some really quite large voltage spikes on the order of many tens of volts (although pretty short duration, measured in ms) which would also kill the LED. You probably could remove the MCPCB from this light and put an XHP70 on SinkPad/Noctigon in there, with some other driver if it was small enough. Downside of going to an XHP70 would be the dark spot in the middle of the beam and the loss of the MT-G2’s beautiful tint, but you would probably be able to get more total lumens out the front. Does that make sense?
Automotive power can be quite dirty with lots of spikes and sags, and I wanted to be able to run mine regardless of whether the engine is off and it’s getting as low as 10 volts or up to 30 or so volts on a 24v system and still have the same brightness. I’d rather not fry $60 worth of MTG2s because my truck decided to make 2 extra volts
Quick note bigC, it’s not the battery itself that causes the spikes, it’s the vehicle’s charging system and in particular starting the vehicle and the ingition that causes all kinds of weirdness.
couldnt you just get a 12v regulator ?? and by 12v, i mean TWELVE VOLT regulator, not a standard 13.8 automotive one? run a line from the battery to the 12v regulator… to the 12v LED… ??
with a big enough heatsink, just let it draw what it wants, regulated to 12v…
Wow, decent built quality
i like how the use LT3756 instead “cheapo” buck controller
LT3755-6 can be configured in Boost, Sepic and Buck
all of the circuit had been write down in the datasheet (buck at page 24)
yes those R036 will be current sense resistor
maybe you should change/stack another schottky on those SS36 if you have to crank up the current more
No big deal. MT-G2s are 6v LEDs. Lower the voltage of the regulator and parallel wire them, or feed the 12v after the regulator to a boost driver. The 12v regulator is only to prevent the spikes from frying the LEDs, you should be able to do what you want with the voltage after it.
How is that a better option than the way they have implemented it? Sounds like you’re doing exactly what their board does when you add a boost driver to a 6v output, or buck driver to a 12v to control it.
I believe these lights are sold individually, so parallel wiring is out unless you DIY it.
I was talking about the stock driver. I misunderstood what you were replying to. In my defense I’m laying in bed with a 102° fever, so I’m not surprised that slipped my attention. Carry on.
