I want to build a handle bar mounted one piece light for mountain biking. aiming around 3000lms.
I have a friend who is going to prototype me up a alloy housing for this once I sort the insides out.
This is where im getting a bit stuck. I got a bit carried away with AI to help me and it seems AI isnt perfect (shock).
My initial idea is to have 3s input probably using 21700s. output side would be x3 leds mounted on mcpcb. I have ordered some 519a’s from convoy and some mcpcbs tripple boards from cutter
I planned on running the leds in series, my thinking was that a buck driver would prefer the smaller difference in voltage between input and output. I could be wrong here…
the mcpcb boards i have on order can be set for parralell or series so im covered if i need to change the led layout.
The bit im struggling with is getting the corrcet off the shelf driver. the internet has guided me to this site via various searches so I have had a bot of a read through some stuff and a look over but still not seeing what i need.
Can anyone give me some pointers.? is there such a thing as a 3s input with correct outputs if im 3s or 3p for the leds. ?
am i being ambitious for my 1st lighting project.. probably. but i like a challenge.
Nice.
I have 4 or 5 of the original lflex v1 boards sitting unused.
I was going to make a few basic bike lights out of them.
Cool thing, fast forward 12 or 13 years and I recently emailed George and he provided me the PDF file for programming.
Was planning on using this little host. I have 2 of them.
You have a greater chance a solder joint leaving the party early than a led failing in 3S setup. In 3P setup you have a greater chance of different Vf and one emitter failing earlier bringing the other two down through overdrive.
the h6flex has a little more meat and mounting into a housing easier with it having components one sided. Are taskled no longer trading officially I see he states that after stock is gone there will be no more…
thats the dream right there… did you design and make the housing also?
I went for the board that takes the smaller leds . although after some more reading I should have probably went 6v 5mm led, there seems to be more off the shelf drivers kicking about.
Mmmmmm, most triples, quads, COBs, etc., already out there would disagree.
I was never a fan of mismatched chips, and back when I made homemade light panels, I’d always toss in small ballast resistors in each string to even things out, but that’s just not Industry Standard™.
Even cheap-ass 9-LED lights to huge showerhead lights just throw everything in parallel.
I’m talking about driving the leds to their limits not underdriving them to the point where a single led can carry the load of all the leds in parallel.
What COBs? The proper ones that run at 36V? Why do you think that’s so?
You might get lucky and get the same binned leds wired in parallel you can also get lucky and get different bins and that’s where the problems might start.
But like I said. You’d get a broken wire in the light before leds failing unless you’re severely overdriving them and your heat management sucks.
I got a 15 years old bike light I built myself still running strong though. And those 4 xpgs are wired in series.
And not to mention the thinner wiring with series. You’d most likely want to use a remote battery and those wires get thick pretty fast.
