Multiple Drivers in single multi emitter light ?
Have anyone tried using Multiple Drivers of the same type, ( example: using 3 or 4 seperate Nanjg 105c drivers in a single multi-emitter light., from the same battery set up from the same switch ? ( meaning their modes would be syncronized to each other, so they all would be in the same mode when turned on ?
There's no need for more than one MCU, one attiny can run, what, itself and 3 8x7135 slave boards? Or more?
It works just the same as stacking more 7135s on one board, they all run in parallel. You just need jumper wires to connect all the right spots together.
