Hey everyone, Im going to build my first light but I’m a noob and am in need of some input from people who know what they’re doing.
I want to build a 1x18650 for edc and as bright as possible of course. I’m going with a convoy s2+ host, love the clean simple look and want more flood than throw. (Next build will be a convoy m2 for more throw) Planning on a single xml2, tint TBD, on a 16mm noctigon. (A 3up will be in the future) and going to get a mclicky forward tails witch.
What I need help on is the driver. I am going regulated not DD. At first I thought 3A of course, but here is where my ignorance and lack of experience comes in. I want as much output as possible while still being reliable and have a decently long service life. The Cree data sheet says the xml2 is rated up to 3A and 10w. With fresh batteries we are talking 4.2v so 4.2 x 3 = 12.6w. So is that a problem for the emitter? Will that over load or fry the led, or does that not matter. Please fill me in
XM-L2s are regularly driven to about 4.4A with Q-lite drivers that have stacked chips. I haven’t read any complaints about shortened life span. I would also expect a little voltage sag, so I don’t think you would get exactly 12.6W anyway.
Well, not only voltage sag, but the LED will only “take” the voltage it needs to turn on at X amount of current. The Cree datasheets tell you what that voltage is. Anything over that “drop out” voltage will be burned up in the driver. The 10W rating is based on the Vf of the LED times 3 amps, and is not an exact number anyway. Cree regularly under-rates their emitters. We know that because of people like Dale (DBCstm, although he wasn’t the first) who are constantly pushing the limits.
3A is definitely not a problem for an xml2. I’ve been using my S2+ for about a year, daily for the last few months. The thing you’ll run into is that after ~10-15 minutes on high it gets hot, you’ll want to back it down to medium to let it cool down.
Ahh I see. For some reason I thought it was the other way around, that it would try to take as much current that it would like when given a certain voltage.
Normally, the LED will try to take all the current that is available in the circuit. Limiting voltage is actually a way to regulate current. We just don’t talk about that here. But, in the case of the current being regulated by the driver to a fixed amount, the LED will take what it is given, with a corresponding Vf level. You can also limit current by using a power supply that is inherently underpowered. That is how LED “throwies” work. That is also how many of the 3x AAA 9-LED cheapie lights work.
Run time vs output is the key element of your build remembering that medium and lower modes can give you extended run time. Installed on a copper DTP mcpcb with a good connection to the host 4 or 5A is not a problem other than being too hot to hold in short order. If you know you want bright then set it up with a nice fat turbo mode and several more modest output options below that. If you know you don’t want gawdawfull bright then other than questioning your devotion to flashaholism I can only suggest you go with a stock 3A Qlite with whatever program modes that float your boat.
Good luck and be sure to post pics and silly assed questions for us to giggle over help you with.
Thanks everyone for sharing your knowledge. I’ve been reading through so many posts and practicing my soldering so I will do this right.
Ok wait one more question. This thermal paste, it goes on between the sinkpad and the pill right? And it is for heat transfer, not a glue to hold the board down correct?
