My first build, need a little help
Trying my first build and need help.
This is my list: I have not bought anything yet.
Convoy M1 Flashlight Host - New Version
The new XM-L2 U4 1C LED on Noctigon 20mm MCPCB
QLITE 7135*8 LED driver- 17mm with two chips added for 3.7 amps
Do I need some sort of spacer for the reflector hole where the emitter goes?
Thanks
Randy
Yep, you’ll need a centering ring/insulator disc to suit the xml.
Something like this;
Link a brother up
Edit: Oh and buy some silicone wire 22awg for the led-driver link.
Some sort of insulation gasket is usually part of the (Convoy M1) Flashlight Host kit, default should be XM-L(2) type.
>>first picture, down middle
Thanks everyone.
I’m in the USA so I’m ordering everything from RMM
I’ll ask him if it comes with one, if not I see them listed.
He has everything you guys recommended.
Do you see any problems with the emitter/driver combo I’m putting in this host?
You’ll need some sort of thermal compound under the MCPCB. And go ahead and get some desolder wick to braid your springs to get the max current out of that setup. Excellent thread on the braid/spring bypass on here recently. RMM’s drivers come with lead wires attached, and his hosts have always included the proper led spacer in my experience. Sounds like a great first build.
Thanks LazyJ
I’ll be using Arctic Silver 5.
I read the thread on the braid/spring bypass and was going to do that.
Also read the thread on adding the 7135 chips.
I’ve done a lot of soldering on my jeep but this will be my first attempt at something this small.
Edit:
RMM returned my email and yes it does come with the emitter spacer for an XM-L2 LED.
Double checking my list and will get everything ordered tomorrow.
Thanks again everyone
