My first driver builds. The good, bad and ugly.
A couple weeks ago I decided I wanted to build a driver…or maybe a bunch of them.
I read through numerous threads here to learn. I decided on some Fet+1 and Texas Avenger fet+1+x as my platforms.
I started ordering pcbs from oshpark. Resistors, caps, fets etc from digikey.
I added a few pcbs to my most recent order from MTN so I had something to tide me over while I wait for stuff from OSH.
Lastnight, my new microscope showed up, so I decided to do a hasty build on an MTN17dd v1.13 FET only board
Applying the solder paste proved to be much harder than anticipated without a stencil.
I’m using Kester ep256. There was no way it was going straight from the syringe onto the board. I squeezed a little onto a silicone mat and used a .3mm apllicator made for applying modeling glue. The paste was pretty grainy (maybe a little dry) and it wanted to stick to the applicator, but not the pads.
I did my best. It was a mess.
Once I placed all the parts on the board in a grotesque fahsion, I was pretty excited to put it on the hotplate.
In my haste, I forgot to put flux on the board. Oops. Once I realized my mistake, it felt like it was too late. I ended up using my c210 iron to hand solder everything under the microscope. I was skeptical that I didn’t mess something up. At this point, I was out of time and had to call it a night.
Fast forward to after work today, I successfully flashed blf-a6-13-rmm.hex. I was excited it flashed successfully.
I was concerned about bench testing it without the proper means to dissipate heat, and I was anxious to see if it worked. So I threw it into a convoy m8+ host.
I used an LHP531. Chucked in a samsung 30Q.
It actually worked!
All the modes work and it’s bright as hell.
Even though it started pretty ugly, I’m excited to do my next one.
I need to figure out a way to make applying solder paste easier/cleaner, without buying a bunch of stencils…yet.
Maybe I need to thin the paste a little with 99% ipa?
Should I flux the board before putting paste on?
Should I be pre tinning anything?
Even though it works, I’d like my future builds to go smoother.
Here are pics of the carnage.
And proof of life.
10 Thanks
What’s the date on it?
Maybe you just need to squeeze some out to get to the fresh stuff.
It should have the consistency of thick toothpaste and shouldn’t look granular like that.
I wouldn’t recommend this.
I would recommend mixing a little flux with it instead.
However you would want to make sure the flux is compatible with the paste.
I try to use the same brand and series with my Solder, Solder Paste and Flux.
I only add flux if I’m reusing a component or pcb and it already has solder on it.
Nah
I use an old computer CPU heat sink.
Good info. Thanks!
I’ll squeeze a bit out into a small container and see if the “good stuff” is further up in the syringe.
I’ll mess around with the stuff I squeeze out and see how that goes as well. You know, for science. I do have compatible kester flux to try out some mixing.
But if the stuff further into the syringe seems good, I’ll use that first and foremost.
I definitely have a few of those around after building computers since the early 90’s.
I used a stencil a few times and didn’t have much luck.
It was for a ATTiny1616 with is 3mm x 3mm and has 21 solder connections.
Yikes. I’ll have to work my way up to those little guys.
Had the same issue with a fresh solder paste syringe, it was dry and crumbled at the beginning.
After some squeezing it got a lot more runny and sticky, I can easily stick a little bit on each pad directly from the needle.
Yea. I ended up pushing a bit out and then it started flowing properly.
I’m doing a 20mm fet+1 as we speak and it’s going way more smoothly.
Just flowed the 20mm board with paste from further up the syringe. Came out way better.
So after playing around with the build for a while, moon mode stopped working.
I did a little digging through old threads and found that the 380ma 7135 chips could be an issue.
So I swapped it out with a 350ma and all the modes are now properly working!
The only issue I’m having is the length of time for medium and long presses.
It’s like 6 seconds to go backward.
Does that mean I need a different OTC Cap?
You’ll need to compile your own version of the A6 firmware after getting the OTC values using offtime-cap.hex.
NOTE: when the light is hot the OTC decay rate is faster. The hotter the light, the faster the decay.
So you’ll want a bit of a buffer.
Also if the voltage readings are off, you’ll need to run battcheck.hex as well.
Okay. I appreciate the help. It looks like I’ve got quite a bit more work. All of my attempts in microchip Studio have been a failure so far. None of the hex files I’ve created have worked on any of the drivers I’ve practiced flashing. I think I just got a lot more learning I need to do.
When you create a new project are you choosing the MCU you’re working with?
Yeah. I’m starting a new project. Executable C. Choosing Attiny13a in the list.
“GCC C Executable Project” right?
And it compiles and it successfully flashes to the mcu?
Maybe the lfuse and hfuse settings are wrong?
Correct.
It compiles/builds and flashes properly.
I believe the fuse settings are correct.
I feel like I’m missing steps somewhere.
Whether its not selecting/uncommenting specific parameters properly.
Do I need to have other files in the project folder for microchip studio?
Or do I just need to work off of a single C file to build the hex?
