This is a SSR-90 with a 9A driver and an aspheric lens from a broken headlight. I used a C8 battery tube and a harborfreight 109 led head. the tower is 180 yards plus or minus. ISO400 F5.6 shutter speed 5. The camera was on a tripod but I was holding the flashlight.
My Xsearcher + XP-G2 3,5A throws 430 KCD (measured on 7 meters) and that is 68mm aspheric, and It could easy be furthest throwing single 18650 light in a world.
Nightmaster V2 with 50 mm head(same emitter) gives 250KCD
I don’t have any way of measuring the light output. I have been looking around for a good meter. Any suggestions? I ordered a xsearcher Saturday. It should be here Monday. I can compare the lights side by side. The lens is 65.6mm. The lens isn’t even really smooth. I has a lot of very small ridges in it.
Well you can compare them side by side but your stock Xsearcher ( I assume 2,5A XM-L2?) will not throw that far since it should have around 100KCD(If you de dome it will be around 150). But maybe I was wrong judging your picture and giving around 300KCD to your?? In real life I could tell difference but by judging the picture I am not to sure.
Looking forward for comparison.
You could fit Xsearsher lenses on your monster(I think they should fit because they could be even smaller than 68mm I am not sure), and then you can compare which will be brighter on same emitter.(lux meter helps a lot in this case).
