Does anyone here have any idea how to ‘re-finish’ it?
For example, the Cu or copper version can be left to the atmospheric elements to tarnish, patina(te), etc. for uniqueness, fun… but does anyone have other ideas of any ‘treatment’ for Stainless Steel?
Posting your works and ideas are definitely welcome!
Remove everything but the ss. Clean the light very well, wear gloves to prevent fingerprints. Heat the light with a blowtorch. Don’t hold the torch on one spot for too long, keep waving. If you have the color you want cool it down in a bucket of water.
This is how I do it, maybe others have a different technique.
Leave it standing up outside and let it rust. It should weep out and run down the sides after a while. (would easily wipe off though so you’d have to coat it)
If you are anywhere near the sea it will rust, unless it’s marine grade stainless of course. The rust will be more like a stain than regular rust which eats in.
It’s too pricey to just buy the product but if you can somehow get your hands on some stainless steel blackener…. Maybe even mask it for some kind of pattern/design…?? Otherwise I think you’re stuck with bluing.
It would be hard to get good looking finish with chemicals or heat treatment from the first attempt. If you don’t know exact alloy or don’t have many cutoffs of same material, you should be ready to polish it after experiments.
@tatasal
It was fully submerged into the solution for about 20 minutes.
But please be cautious because the FeCl is powder and water was added, so the water & FeCl ratio will affect the timing as well.
