Thanks
I thought they look pretty bad since I’ve never taken any beamshots before.
Ok, as stated above it has a fried 20mm Mountain Electronics DD driver, (must have been a casualty) so it has no modes, I will put one in next time I order some parts. XHP70.2 is on a 16mm mpcb, the thorfire has 2 screws holding it down, but just barely. Don’t remember what size mpcb or led it had originally, I assume a 20mm? I also used a small clear insulating gasket, I assume that’s what its called, between the reflector and wires. The cool thing with the C8s is the reflectors fit the xhp70s perfect so no centering ring is needed for the xhp70s and any C8 and most C2s I’ve done. All the extra reflectors I’ve ordered for the C8s have fit the xhp70s perfect, but you may get a “slight hint” of a tiny donut spot in the center at closer distances than 20ft with the xhp70.2, the older xhp70 will have a cross.
Powered by 2 Vapcell 1100mah 18350.
Also its a great host for a xhp50 mod, since it accepts 20mm drivers, with the H1A. But you may as well just buy the Kaidomain C8.2 xhp50 at that point.
