My New Edition and my small collection
Just received my New edition from Chicago X a cut down maglite running on a single 18650 cell. Well pleased with it.
Starting to get a nice little collection together now.
Top row:
All left to right
Blue Custom Chicago X Maglite running single 18650 cell
Green Maglite fitted with 180Lumen LED bulb running on 2x D cells
Red Maglite Fitted with Red LED bulb running on 2x D cells
Silver Maglite fitted with CREE XML-T6 5-Mode 6700K 900-Lumen Aluminum Drop-in running on 2x 18650 cells
Black standard incan 2C maglite waiting for conversion
TrustFire TR-3T6 running on 3x 18650 cells
Middle row:
Sky Ray King (older T6 model) 4x 18560 cells
Streamlight Sidewinder Sportsman 2x AA cells
No make 21 LED 3 x AAA cells
kleto XM-L T6 single 18650 cell
No make single 18650 cell
Bottom row:
2 x CountyComm Maratac AAA Copper Flashlight Rev2
ThruNite T20 C123 cell
Fenix E15 C123 cell
ThruNite Ti Black AAA cell
ThruNite Ti Green AAA cell
Fenix E01 AAA cell
ThruNite Ti silver body gold head AAA cell
Maglite Solitare AAA cell
Rofis JR 20 single 18650 cell
Crelant 7G3CS single 18650 cell
Hugsby P2 C123 cell with extention tube for AA cell
Also not in picture 2 x ThruNite Ti 1 x Black and 1 x Blue
That's a very classy light you have there with that bezel. Nice collection as well.
Very nice collection !
Can you identify the torch directly below the silver Mag, please?
No make on it Wayne, but it’s a cheap 21 LED that runs on 3 AAA cell the switch is in the tail cap, press for momentarily or tighten the cap for permanent. Can’t even remember where it came from as had it for many years. the glowing part is just some 3M reflective tape.
Nice collection indeed! What is the one below the red Mag and to the right of the King?
That is a Streamlight sidewinder sports very nice light, more details can be found here http://www.streamlight.com/product/product.aspx?pid=168
or you can read my review on my website here http://thebushcraftforum.co.uk/content/streamlight-sidewinder-sportsman-63/
Very nice collection and the Maglite is awesome!!! Love the little skulls… :wink:
The blue Maglite looks really nice, great work Chicago X!
Run it on 26650 instead, greatly increased runtime…
When I finish modding my 4D incan, xm-l u2 and 3.04 amp driver in place but cut-down still to be done, it will run on a single 26650.
Are the 26650 cells the same size as a C cell, as I was thinking of converting my C maglite to run on 2 off the 26650 cells and fitting a FUSION 36 LED POWER MODULE as all my other maglites have been converted for throw so looking to convert my C maglite to a flood light.
if i remember right, the 25500 is closer to the same size as a c cell. the 26650 is too long, and a hair too wide
Thanks Pulsar, will have to check the specs to see if 2 will fit in a C maglite.
Also updated first post to inc details of my lights. :wink:
Awesome collection, thanks for sharing!
As always, nice job Chicago X. :wink:
Sadly 26650s will not fit in a C mag. C cells are around 25.2mm and 26650s are around 26.3mm.
Thanks for that Scaru good excuse to buy another 2D maglite for my fusion drop in :wink:
I know this is a slightly old thread. But I wanted to throw out there that an older Mag (no C is serial number) actually WILL accommodate a 26650 with no modifications. Also, although a 2C is too short for 2x26650, a 3C is pretty much spot-on. It’s also only a little longer than a 2D (maybe an inch with the heads on both fully retracted). But unlike a 2D, it requires NO tailspring/tailcap mods - it’s pretty much ready to go ‘out of the box’. So if you want to run 2x26650 in a Mag with zero fuss, an older 3C (no C in serial number) is the way to go. It’s almost like it came from the factory specifically for that purpose.
I should also add that a newer C cell Maglite (with C in the serial number) will accept a 26650 if you enlarge the inside of the tube. This is often done with a brake hone. But some people have done it even with more improvised methods, like spinning a crumpled ball of sandpaper on the end of a long drill bit.
