In my Suzuki GN125
I buy locally, almost no specs info… I buy it because a friend buy the 12 Leds version for his klr650
Take it from a ebay seller:
Power: 18 W
.Voltage: 9-32 V
.Theoretical Lumens Output: 1800 LM
.Operating Lumens Output: 1260 LM
.LED: 6pcs*3W (CREE LED)
.Beam: Spot Beam (30 degree).
(we also have 60 degree,if you want,please mail us once you paid,thanks)
.Color Temperature:6000K
.Working life: 50000 hours
.Working temperature: –40~ 85℃
.Size: 99*73*107mm
.Certificates:CE、 RoHs、 IP67
. Material: 6063 aluminum profile, stainless steel bracket, PC Lens.
. LED Light Bar Low Current Draw means no harms to battery and save gas.
. Designed To Withstand Any Condition, 6063 Aluminum Body For Strength And Durability.
. Vertical Fins Maximize Heat Dissipation,Advanced Heat Sink Designed To Prolong The Life Of The LEDs.
. Wide operating voltage range: it can apply to different types of trucks, Off-road vehicles, 4x4, Military, Mining, Boating, Farming, Heavy Equipment etc.
. The light output of these LED light bar is simply phenomenal, they produce a mass of clean white daylight (6000k), free of artifacts and focus dead spots. They light the entire forward viewing area, giving greater visibility without eye fatigue.
. Their super efficient reflector uses patented Hybrid Technology, allowing these lights to runs at 93% optical efficiency, which is unmatched in the industry. Each LED light bar consists of two rows of high intensity LEDs, each sitting in their patented reflector assembly, measuring about 1 inch square. Each LED is independent, so if one LED fails the other LEDs will not and the LED light bar still works fine.
Package includes:
2pc 18w led work light (SPOT Beam)
Necessary accessories
