Nanjg 105c in Eagletac D25C, Batt+ contact board question
A while ago I made a mess of my eagletac d25c Welp, Im an idiot - D25C Ti disassembly failure so now I decided to put a DrJones nanjg 105c driver in it. I am going to reuse the battery+ contact board but the stock eagletac driver has two mode groups, one with the head fully tightened and one with it loosened a hair. Now I am not sure which ground contact on the back of the contact board is for the head fully tightened and which is for it loosened. The GND on the left is just soldered to the brass board. The “upside down” GND on the right’s wire was connected to the ground ring on the driver while the signal/GND was connected to the right side of the driver in the 2nd pic. Any ideas as to which is which?
Can you measure all the pads/rings on the contact board with an ohmmeter and map out what goes where?
What’s the overall diameter of the driver in the D25C? Also what’s the diameter of the emitter MCPCB?
